Results 1 to 7 of 7
Thread: Torque of rocker or valve cover bolts on TB48E
    Mar 2015
    Anybody know the torque settings on the TB48E valve cover bolts, sometimes referred to as the rocker cover. Have checked the Workshop manual, but TB48 in my collection do not have the torque settings, can see for the TD42 it is very low 2-3 Nm.
    Sent from my LG-H818 using Tapatalk
    Vanhack
    2012 LWB Auto 4.8 Patrol
    www.quickpitchgcc.com
    43 Post(s)
    Yep me and my brother have just done valve clearances and the rocker cover bolts need bugger all tension..
    I snapped one and I had stuff all force on it..
    So when you feel it getting tight stop. Lol
    And no leaks in mine so must be right..
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    Yep 2-3 Nm for all 6mm bolts
    Mar 2015
    Thanks folks. Hopefully the rocker gasket is where my oil is leaking from and not my head gasket.
    Sent from my SM-T805 using Tapatalk
    Vanhack
    Quote Originally Posted by vanhack View Post
    Usually you'll see oil around the bolt heads
  7. The Following User Says Thank You to Winnie For This Useful Post:
    vanhack (25th January 2016)
    Mar 2015
    Anyone know which of the O2 sensors plugs are bank 1 and 2, connectors are identical, and I did mark them. I have O2 sensors before cats only.
    Vanhack
    Patrol Guru
    Apr 2011
    Melton
    I ended up replaceing the rocker bolts with normal bolts as the head of my bolts werestripped.
    it was around m6 * 25 mm
  10. The Following User Says Thank You to GQ TANK For This Useful Post:
    BigRAWesty (25th January 2016)
