25th January 2016, 05:36 AM
Torque of rocker or valve cover bolts on TB48E
Anybody know the torque settings on the TB48E valve cover bolts, sometimes referred to as the rocker cover. Have checked the Workshop manual, but TB48 in my collection do not have the torque settings, can see for the TD42 it is very low 2-3 Nm.
Sent from my LG-H818 using Tapatalk
25th January 2016 05:36 AM
25th January 2016, 07:59 AM
Yep me and my brother have just done valve clearances and the rocker cover bolts need bugger all tension..
I snapped one and I had stuff all force on it..
So when you feel it getting tight stop. Lol
And no leaks in mine so must be right..
25th January 2016, 09:17 AM
Yep 2-3 Nm for all 6mm bolts
25th January 2016, 10:22 AM
Thanks folks. Hopefully the rocker gasket is where my oil is leaking from and not my head gasket.
Sent from my SM-T805 using Tapatalk
25th January 2016, 10:24 AM
The 747
vanhack
Usually you'll see oil around the bolt heads
vanhack (25th January 2016)
25th January 2016, 11:30 AM
Anyone know which of the O2 sensors plugs are bank 1 and 2, connectors are identical, and I did mark them. I have O2 sensors before cats only.
25th January 2016, 12:44 PM
I ended up replaceing the rocker bolts with normal bolts as the head of my bolts werestripped.
it was around m6 * 25 mm
The Following User Says Thank You to GQ TANK For This Useful Post:
BigRAWesty (25th January 2016)
