24th January 2016, 10:07 PM
'Tee' crimp cable connectors?
Is there such a thing as a T crimp connector for 6 B&S cable? I haven't been able to find one - for any size cable.
I want to split from a single incoming cable to feed 2 outputs, all with the same size cable. I'd much prefer to use decent crimp connections rather than strip and solder.
Is soldering my only option? How do others make a secure and safe T joint?
24th January 2016 10:07 PM
24th January 2016, 10:23 PM
Legendary
Don't know mate never had the need, but I would speak to a battery supply place.
The Following User Says Thank You to 4bye4 For This Useful Post:
Brissieboy (25th January 2016)
24th January 2016, 11:15 PM
Patrol Guru
You could use Anderson plugs with larger size conectors where the two cables come into one plug
http://www.ebay.com.au/itm/50-Amp-An...QAAOSw-ndTnlKT
98 GU ST wagon 6.5TD chev 5 speed manual dual batteries storage drawers big red air compressor 9L tank millweld front and rear bars millweld 4" snorkel 4" air box 3" tough dog suspension lift drop box and hybrid radius arms 12000Lb winch ARB front air locker Alpine MP3 player amp and a good set of speakers GME 2 way The list goes on
The Following User Says Thank You to Kimbo63 For This Useful Post:
Rock Trol (24th January 2016)
24th January 2016, 11:57 PM
I am he, fear me
The usual method for 1 into 2 is to use a buss bar type interconnection
Especially in higher current applications
Link for illustration purposes http://www.ebay.com.au/itm/DC-2-3-or...3D262191507673
The Following 3 Users Say Thank You to the evil twin For This Useful Post:
BigRAWesty (25th January 2016), Brissieboy (25th January 2016), Kimbo63 (25th January 2016)
25th January 2016, 10:56 AM
Smart like tractor
Brissieboy
Lug and bolt them together and cover with self amalgamating tape, electrical tape and heatshrink
96 GQ coil/Cab
08 G6eT
The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
Brissieboy (28th January 2016), threedogs (25th January 2016)
25th January 2016, 03:35 PM
@ ET do those buss bars have covers to protect them from the elements ??
25th January 2016, 03:46 PM
Hardcore
Ben-e-boy
+1
If I didn't want to bus bar or split off from a fuseblock lug this is probably how i would join 2 big cables
Lucus30's 1999 GU ST TB45E
The Following User Says Thank You to lucus30 For This Useful Post:
