Results 1 to 7 of 7
Thread: 'Tee' crimp cable connectors?
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Is there such a thing as a T crimp connector for 6 B&S cable? I haven't been able to find one - for any size cable.
    I want to split from a single incoming cable to feed 2 outputs, all with the same size cable. I'd much prefer to use decent crimp connections rather than strip and solder.
    Is soldering my only option? How do others make a secure and safe T joint?
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Don't know mate never had the need, but I would speak to a battery supply place.
  4. The Following User Says Thank You to 4bye4 For This Useful Post:
    Brissieboy (25th January 2016)
    Patrol Guru Kimbo63's Avatar
    Dec 2015
    Perth WA
    5 Post(s)
    You could use Anderson plugs with larger size conectors where the two cables come into one plug
    http://www.ebay.com.au/itm/50-Amp-An...QAAOSw-ndTnlKT
  6. The Following User Says Thank You to Kimbo63 For This Useful Post:
    Rock Trol (24th January 2016)
  7. #4
    The usual method for 1 into 2 is to use a buss bar type interconnection
    Especially in higher current applications
    Link for illustration purposes http://www.ebay.com.au/itm/DC-2-3-or...3D262191507673
  8. The Following 3 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (25th January 2016), Brissieboy (25th January 2016), Kimbo63 (25th January 2016)
  9. #5
    22 Post(s)
    Quote Originally Posted by Brissieboy View Post
    Lug and bolt them together and cover with self amalgamating tape, electrical tape and heatshrink
    96 GQ coil/Cab
    08 G6eT
  10. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    Brissieboy (28th January 2016), threedogs (25th January 2016)
  11. #6
    @ ET do those buss bars have covers to protect them from the elements ??
  12. #7
    Hardcore lucus30's Avatar
    Sep 2013
    16 Post(s)
    +1
    If I didn't want to bus bar or split off from a fuseblock lug this is probably how i would join 2 big cables
    Lucus30's 1999 GU ST TB45E
  13. The Following User Says Thank You to lucus30 For This Useful Post:
