24th January 2016, 03:57 PM
Patrol Guru
+ve wire in cab when on ON
Hi All,
Trying to wire in my EGT gauge and trying to identify a wire that supplies +ve inside the cab, I've got the service manual here but can't make head or tail of the wiring diagrams.
Fish
24th January 2016 03:57 PM
24th January 2016, 04:14 PM
Remove the front facia plate around the radio
and you'll find a POS and an ign pos as well
gubigfish (24th January 2016)
24th January 2016, 06:53 PM
Patrol Guru
Well I found a wire that I though was on or ACC when testing it with a multimeter, switched the car off and no volts just connected it to the gauge and its directly connected to the battery. There were a few expletives let out
24th January 2016, 07:13 PM
There's an ignition feed coming into the diagnostic plug that's easy access
John
24th January 2016, 07:20 PM
I think i picked mine up off either the factory spot light switch in the dash or the dash dimmer.. can't remember exactly... But best past was the wiring was long enough to pull the switch out of the dash and do all the wiring from the drivers seat without having to break my back with jap hands laying on the floor working over head.
2003 GU SIII Auto Grenade. All the goodies.
24th January 2016, 08:08 PM
The 747
Cigarette lighter is an easy one
The Following User Says Thank You to Winnie For This Useful Post:
gubigfish (25th January 2016)
24th January 2016, 08:19 PM
The Following User Says Thank You to Sir Roofy For This Useful Post:
24th January 2016, 08:40 PM
#8
Patrol Guru
Winnie
X2, that is what I use.
The Following User Says Thank You to TimE For This Useful Post:
25th January 2016, 12:07 AM
#9
I am he, fear me
Try one of these and you can pick up whatever power you want IE Battery, Accessory or Ignition
http://www.ebay.com.au/itm/321430422...%3AMEBIDX%3AIT
The Following User Says Thank You to the evil twin For This Useful Post:
25th January 2016, 02:28 AM
#10
Patrol Guru
Cheers ET looks like a good option and a bit neater than splicing into existing wires
