Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Tb42 missing straight petty carby details inside
    Or a worn 4th lobe on the dissy shaft.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    Virgil9 (3rd February 2016)
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    I guess they came from factory with that length rotor button and not missing so you'd think there's another issue away from the length of rotor button... But they can be a little bitchy lol...comes down to swapping bits which luckily is not too expensive
    >>>tappin from tassie
    Hello from Under Down Under!
  5. #13
    Jan 2016
    Darwin
    Ah are there any ways to see if it is a worn 4th lobe?
  6. #14
    Aug 2011
    North West Tas
    56 Post(s)
    Remove the dissy and use a feeler gauge to check the gap when on the fourth cylinder.
    >>>tappin from tassie
  7. #15
    Jan 2016
    Darwin
    Food for thought, cheers.
  8. #16
    Jan 2016
    Darwin
    Ok all found the problem. The lobes were not lubricated so the breaker block was worn causing the point in the dizzy not to open on the 4th lobe. I adjusted and lubbed it up. Working perfect. Thanks all for the tips
  9. The Following User Says Thank You to Virgil9 For This Useful Post:
    taslucas (28th January 2016)
  10. #17
    Aug 2011
    North West Tas
    56 Post(s)
    Great to hear it's fixed mate.
    >>>tappin from tassie
  11. #18
    Jan 2016
    Darwin
    Yes its running great. Love the tb
  12. The Following User Says Thank You to Virgil9 For This Useful Post:
    taslucas (31st January 2016)
  13. #19
    Glad you got it going. Thanks for the feedback, as it might help others.
  14. The Following User Says Thank You to mudnut For This Useful Post:
    Virgil9 (31st January 2016)
  15. #20
    Patrol Guru
    Apr 2011
    Melton
    I suggest you consider upgrading to pertronix, as there are no moving parts to wear out
