20th January 2016, 07:18 PM
2012 CRD Almost stock 2" lift kid recomendation
Hi All,
Looking at my next big thing for the GU, it is almost stock (alloy bull-bar and dual battery)
Front - 1340kg
Rear - 1260kg
Considering one of these two options, any recommendations please;
1.Superior Engineering
The kit includes the following Superior Suspension Parts:
2x Front coils
2x Rear coils
2x Front Superior Engineering Nitro Gas Shocks
2x Rear Superior Engineering Nitro Gas Shocks
1x Superior Engineering Steering Damper (Which I don't need)
4x Castor correction bushes
2. Ironman foam pro + Ironman or any other springs
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
The Following User Says Thank You to MyGU8 For This Useful Post:
growler2058 (20th January 2016)
20th January 2016 07:18 PM
20th January 2016, 07:21 PM
20th January 2016, 08:10 PM
Dribble Master
fitting yourself or getting them fitted?
for around $800, you could get a set of king springs (off ebay) and shocks (depending on the brand)....... I went TerrainTamer shocks bought locally in Perth for just over $500 and the King springs off ebay.
But like Growler said, what sort of 4wding are you planning?
20th January 2016, 08:15 PM
growler2058
Whaddya want it to do? All round tourer, or hard core with the Victorian mob ? Or Both?
Mostly town running, 25% rough roads but nothing hard core like rock crawling.
Loaded with camping stuff when going out but nothing extremely.
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
20th January 2016, 08:18 PM
Clunk
I can fit it myself but wondering what sort of tools I will need. Fairly mechanical minded so won't be a biggie but tools may get in way
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
20th January 2016, 08:29 PM
SPAMINATOR
escix
Well TJM XGS Gold or ARB Old MAn Emu (OME) with the correct spring rating and youll be fine.
If you are gunna fit it yourself you need spring compressors metric socket set, H/D axle stands and a good trolley jack
20th January 2016, 08:42 PM
Moderator
no spring compressors required for a 2" lift. i have installed 6 " springs without compressors
what is your budget? i am a big fan of Old Man Emu 2" lift mate. great match to your car.
Check out my Toy -->
Rogue Dung Beetle
The Following User Says Thank You to MudRunnerTD For This Useful Post:
MyGU8 (20th January 2016)
20th January 2016, 08:59 PM
MudRunnerTD
As cheap as possible
Both of my original proposal come around $1300. Ironman installation is only $100.
Recently I came across some comments here about Ironman pro performing better than ome, I was originally to go with ome.
I know it is a personal thing but ride quality is I am after
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
20th January 2016, 09:09 PM
The Following User Says Thank You to growler2058 For This Useful Post:
21st January 2016, 10:20 AM
Will you be towing in the near future, and have you finished all your accessories
like dual battery etc ??? swapping the alloy bar for a steel number
The Following User Says Thank You to threedogs For This Useful Post:
MyGU8 (21st January 2016)
