18th January 2016, 12:27 PM
Wanted Battery isolator with damaged microcontroller
Hello All,
Hope you all had a great weekend.
I am looking for a dual battery isolator which you like get rid of due to damaged circuit.
My plan is for a test circuit with arduino to see how well it can be utilised in dual battery arrangements.
Happy to pay for postage.
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
18th January 2016 12:27 PM
18th January 2016, 12:49 PM
escix
Hello All,
I have a couple that still work but am not using.
Think I'll keep one just incase
18th January 2016, 01:36 PM
Thanks Mate,
PM sent.
Cheers,
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
18th January 2016, 03:39 PM
escix,
You might be better looking for an alternative to an Arduino. The Atmega processors are not low power so you will end up with a steady drain on your battery. It's not huge (around 20mA or so just for the processor is what I have noticed) but a low-power processor will be a LOT less. And you don't need much computing grunt for something as simple as a VSR.
18th January 2016, 06:34 PM
BB, the main power consumption in arduino is from the voltage regulator. If I am using the Atmega328 then the power usage is in mA (around 25mA) and again at 5V.
This, I believe will be much less than the radio standby power requirement.
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
18th January 2016, 06:40 PM
Got your pm and will try and send off tomorrow..
The Following User Says Thank You to Bloodyaussie For This Useful Post:
MyGU8 (18th January 2016)
18th January 2016, 06:43 PM
Will this one be ok.?
19th January 2016, 12:25 AM
#8
As far as the relay and solenoid is working that should be fine bloodyaussie.
The circuit is no use to me as it will be replaced by the arduino
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
