Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Need an extra 20L fuel??
  1. #31
    Patrol Guru Covo71's Avatar
    Dec 2012
    Coffs Harbour
    So I am probably a bit dopey. The 16mm ring spanner isn't undo anything, you just used it to bend the pipe? Hard to see in the pic but it looks like the pipe runs flat along the top. How far does the pipe go past the 2 brackets it is welded to?
    43 Post(s)
    Yep. Ring over the end and try flatten the last kink a little.
    You don't have to do that, it'll just mean the pipe end is a bit lower..
    The pipe tip is about 70 odd mm past the second bracket..
    There are 2 brackets. One is just flat steel and the other has a small brace but a good squeeze sorts it..
    Jul 2014
    6 Post(s)
    Is this dangerous? Can the fuel run out of the breather or something?
  5. #34
    43 Post(s)
    Quote Originally Posted by Throbbinhood View Post
    The only way fuel can come out the tank
    Is via the feed line or filler caps..
    And a bloke with more brains than me did some Calcs on deisel expansion..
    From memory he said every 100L expansions was only a little over 100m ls from 0 to 40 degrees..
    So yea.. the space given by nissan is huge..
    Jul 2014
    6 Post(s)
    So there's essentially no risk to this then, moreso if using ULP?
    Any way to do this without removing my draws? Lol!
  7. #36
    43 Post(s)
    Yep.. drop the tank lol
    Jan 2016
    For people waiting for fuel to settle after a click, I tend to take both caps off and alternate between the main and sub with every click until they are both full.
  9. #38
    Aug 2011
    River Heads Q
    4 Post(s)
    Both my GU and my son's GQ utes leak fuel from cap or breather when filled to max and parked in sun so we have to drive using both tanks to avoid problem.
    This only happens when we take time and fill to max when going on extended trips.
  10. #39
    43 Post(s)
    Quote Originally Posted by Wizard52 View Post
    Is this with fuel stayung visible in the neck after filling?
    I haven't had any spill with the gq nor now the gu..
    North brissy
    Used to get the same filling bothing tanks up in mackay. The heat was enough to cause a constant drip from the fillers until it cooled or level dropped. This is only filling to the cut off so only one click of the pump.
  12. The Following 2 Users Say Thank You to nissannewby For This Useful Post:
    BigRAWesty (30th March 2016), threedogs (31st March 2016)
