5th March 2016, 07:55 PM
#31
Patrol Guru
So I am probably a bit dopey. The 16mm ring spanner isn't undo anything, you just used it to bend the pipe? Hard to see in the pic but it looks like the pipe runs flat along the top. How far does the pipe go past the 2 brackets it is welded to?
5th March 2016 07:55 PM
5th March 2016, 08:01 PM
#32
Yep. Ring over the end and try flatten the last kink a little.
You don't have to do that, it'll just mean the pipe end is a bit lower..
The pipe tip is about 70 odd mm past the second bracket..
There are 2 brackets. One is just flat steel and the other has a small brace but a good squeeze sorts it..
7th March 2016, 11:51 AM
#33
Is this dangerous? Can the fuel run out of the breather or something?
7th March 2016, 02:32 PM
#34
Throbbinhood
The only way fuel can come out the tank
Is via the feed line or filler caps..
And a bloke with more brains than me did some Calcs on deisel expansion..
From memory he said every 100L expansions was only a little over 100m ls from 0 to 40 degrees..
So yea.. the space given by nissan is huge..
7th March 2016, 03:14 PM
#35
So there's essentially no risk to this then, moreso if using ULP?
Any way to do this without removing my draws? Lol!
7th March 2016, 04:50 PM
#36
29th March 2016, 08:43 PM
#37
For people waiting for fuel to settle after a click, I tend to take both caps off and alternate between the main and sub with every click until they are both full.
30th March 2016, 12:11 PM
#38
Both my GU and my son's GQ utes leak fuel from cap or breather when filled to max and parked in sun so we have to drive using both tanks to avoid problem.
This only happens when we take time and fill to max when going on extended trips.
30th March 2016, 01:21 PM
#39
Wizard52
Is this with fuel stayung visible in the neck after filling?
I haven't had any spill with the gq nor now the gu..
30th March 2016, 01:44 PM
#40
Wizard52
Used to get the same filling bothing tanks up in mackay. The heat was enough to cause a constant drip from the fillers until it cooled or level dropped. This is only filling to the cut off so only one click of the pump.
The Following 2 Users Say Thank You to nissannewby For This Useful Post:
BigRAWesty (30th March 2016), threedogs (31st March 2016)
