18th January 2016, 09:41 PM
Indicators stopped working
Hi All. My indicators have stopped working. Have checked the fuses like everyone said but they are all fine. Even the hazard one. Could it be the relay and how easy is it to replace this?
18th January 2016 09:41 PM
18th January 2016, 10:29 PM
Yeah the indicator relay is found under the rhs of the dash. Its blue in colour and you can simply use another one of the blue relays there to test it out.
18th January 2016, 11:40 PM
I am he, fear me
mudski
You sure about that?
Mine is behind the centre dash and it should only have 3 pins "B", "L", and "E"
19th January 2016, 12:37 AM
If your hazard lights are still working then it can't be a faulty flasher relay.
The flasher relay is located below the radio on the RHS. Inline with your left knee when sitting in the drivers seat. If you look up from the clutch pedal towards the back of the radio you will see the black rectangle box with 3 wires going to it.
19th January 2016, 01:36 AM
Check the wiring on the hazard light switch, if it is disconnected the indicators won't work
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
