Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: ZD30 intercooler
    Advanced Oddie1969's Avatar
    Jun 2013
    Perth
    ZD30 intercooler
    Hi all. Just wondering if someone could tell me how hard it is to change the intercooler on a 2006 3.0lt. I’ve misplaced my Haynes manual so I’m just wondering if it’s just remove and replace of is there more involved than that ?
    Thanks in advance
    Graham
    465 Post(s)
    Should take less than a stubbie to remove and refit. Two hose clamps, unclip a sensor and four bolts....
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (21st July 2020), Oddie1969 (21st July 2020)
    Jun 2013
    Perth
    Right, that sounds like something even I might be able to manage, thanks 👍
    Patrol Freak Mc4by's Avatar
    Oct 2016
    Mandurah W.A.
    7 Post(s)
    I don't know a screwdriver from a spanner and I got it done on my own.
    I did leave a blanking bolt out but got that sorted quickly
  7. The Following User Says Thank You to Mc4by For This Useful Post:
  8. #5
    Jun 2013
    Perth
    Quote Originally Posted by Mc4by View Post
    Ha ha. 🤣 Mine is leaking a lot of oil so I wasn’t sure if there were oil lines that needed to be considered, after a bit more reading it looks like that may be coming though with the air.
  9. #6
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    When you say "fitting a new one" are you talking original or aftermarket? Some of the aftermarket ones (like the one I purchased years ago) are a pain to fit. Most Patrol owners these days get the original IC modified by getting the core removed and a more efficient core TIG welded in its place. This gives you better cooling of air plus it wont leak AND it is guaranteed to fit.
  10. #7
    May 2016
    lower west victoria
    30 Post(s)
    Quote Originally Posted by Oddie1969 View Post
    Yep, do you have a catch can fitted?
    I live in the "don't know a screwdriver from a spanner" drawer as well plus I specialise in forgetting things, but the oil will be coming from your PCV blowing back into your air inlet. The catch can goes a fair way towards removing that oil. Please someone correct me if I'm wrong.
    There's not meant to be oil in the IC, just wind.
  11. #8
    easy enough to change once the engine cover is removed.
    Not sure on prices but a change over IC fully tigged will
    be approx 33% bigger
  12. #9
    Jun 2013
    Perth
    Aftermarket direct swap. Welded instead of crimped but all the same dimensions. All done, went in like a dream.
  13. #10
    Jun 2013
    Perth
    Ha ha, we sound like twins !
    No I don’t have a catch can, I was reading about those, are they worth it ? Do I need to be cleaning anything else so the intercooler doesn’t get clogged up again ?
