12th January 2016, 11:43 AM
#11
NissanGQ4.2
Yeh wish I still had mine, but got what I believe was a price that I doubt I would of got again so was 2 hard 2 pass up
But then you have no bike :-(
Hello from Under Down Under!
12th January 2016 11:43 AM
12th January 2016, 12:17 PM
#12
Ive matt blacked heaps of road bikes over the years , all you need to do is mask off the barrel from the cases.
Remove and polish tappet covers, spray and either wipe wet paint off the fins or use a file, not that hard.
As you said looks trick too, just like a later model
EDIT::: and it sticks, as you basically oven bake it on.
If you spray with the motor warm and not hot it will open the
pores a tad and fill in with paint better,
Never had one peel off ever and I rode bikes for a very long time
Main reason I did it was to make my bike different to one anyone can buy, lol
The Following User Says Thank You to threedogs For This Useful Post:
taslucas (12th January 2016)
12th January 2016, 03:22 PM
#13
Patrol Guru
If you just want to 'clean' the alloy -ie get rid of the dirty grey look -get some aluminium acid like chemtech blitz - white bottle / black label from super cheap , or septone aluminium cleaner -green bottle with yellow label ( from memory) dilute either of em 50/50 with water & spray on , let sit for 5 mins then hose off , repeat until clean - you can help it along with a toothbrush in the hard to reach bits & a normal scrubbing brush on the bigger areas - you don't need to scrub it hard it will simply wipe off with your finger, like anything if you spray soap on and just hose it off it will be clean but leave the residue this stuff is the same. after a couple of goes it will be clean but very bright - not quite white but very light & bright . Not sure if that's what you're after or if you really want to polish it that is a bloody big job
2002 GU wagon 3.0lt , auto , piranha dual batteries , 3" lift , chip , needle & Dawes valves - just gettin started
The Following 2 Users Say Thank You to Sprock For This Useful Post:
Avo (12th January 2016), taslucas (12th January 2016)
12th January 2016, 03:32 PM
#14
yep what sprock said,works a treat,just don't leave it on to long.....
The Following User Says Thank You to Avo For This Useful Post:
12th January 2016, 03:35 PM
#15
Patrol Guru
The Following User Says Thank You to Sprock For This Useful Post:
katwoman (13th January 2016)
12th January 2016, 03:38 PM
#16
Patrol Guru
Sorry I got a bit carried away there ! Went looking for a picture to show the work that goes into cleaning , sanding and polishing alloy for a Mira finish if that's what you're after but I think you just want to clean that head up to look more respectable ?
12th January 2016, 04:49 PM
#17
Sprock
Haha no worries! Thanks for the info. Yeah there's no way I'm going for a mirror finish. Just a clean up will do.
Edit: that bumper looks mint!!
12th January 2016, 05:18 PM
#18
Patrol Guru
Thanks mate
13th January 2016, 08:10 AM
#19
Hey threedogs, do you have any pics of the bikes you painted black?
tappin from tassie
13th January 2016, 03:51 PM
#20
taslucas
tappin from tassie
Ill see what I can dig up
Found some but puter is playing up for some reason.
For early Honda superbikes I had some rippers
refused to buy a kwaka 9 cause I could get a 750 to eat them
