Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Belt squeeling.
    462 Post(s)
    Mine squeals for the first 30 seconds while accelerating then stops. Have replaced the belt and tensioner. If I stop for ten minutes and start up again it'll do it for 10 seconds before it stops
    Have a look at your egr pipe. If it does it while accelerating then stops, your motor is under load and high exhaust temps. As for the second part, when you stop the pipe cools, the metal shrinks and the split opens just that little more, then when it gets hot the metal expands, closing the split slightly.
    Ive seen this before on a crd, but it could be something else too. Best thing to do is just make up a plate for the egr pipe on the exhaust side. So if the pipe is split it wont matter.
    BigRAWesty (19th January 2016)
    Feb 2011
    Shed
    45 Post(s)
    What are all the other pipes that run off from the inlet side. Will that matter if I block the bastard on the turbo side?
  5. #13
    Patrol Guru ova50's Avatar
    Nov 2011
    Syd, Northern Beaches
    Had a squeal on two different occasions.
    The first time a couple of years back, it was the exhaust manifold gasket. (fortunately fixed under warranty) At the time I was told it is not uncommon. The dealer replaced the manifold studs in the head and also machine the manifold, which was recommended.
    The second time I thought it was the same problem because it had a similar sound. This time it was the alternator pulley that was causing the noise.
  6. #14
    Aug 2010
    Adelaide - Northern Suburbs
    Hey Folks - how much (roughly) for belt and tensioner replacement? 2006 GU 3.0TD Manual and Nissan have just quoted me $700 to replace both ..... am I being robbed blind, or is this reasonable?
    Can still under extended warranty from purchase date, so sticking with original parts and Nissan fitting etc (where possible).
    2006 GU ST 3.0td manual. CTEK 250S Dual Battery - Ironman 65L Ice Cube - Pioneer AVH-3600DAB - Tough Dog Adj 45mm Shocks, springs and HD steering damper - Airtec Snorkel - King Brown 3" exhaust
  7. #15
    If you have extended warranty then the Tensioner is covered but the Belt isn't... I had two tensioners replaced for nix over 6 years
    Get them to 'fix the squeal' and you should only pay for the belt
  8. The Following User Says Thank You to the evil twin For This Useful Post:
    tracemul7 (2nd March 2016)
  9. #16
    Aug 2010
    OMG you are an actual genius!
    Just waiting for Nissan to confirm they will put it through under the warranty and get it done on Monday
    It's really noisy on startup for a few mins (once warm, it's fine) .... am I risking any damage by driving it like this?
  10. #17
    Aug 2010
    Quote Originally Posted by tracemul7 View Post
    Nissan have confirmed it's covered 😀 just belt to pay for (around $100)!!
    Haven't been on here for ages, but glad I popped back in!! 👍
  11. #18
    If you don't have a spare Serpy belt and they replace it, tell them you want the old one back.
    Inspect the old belt and if it is 1/2 way decent keep it as a spare
