6th February 2016, 11:25 PM
Yendor
Thanks Kimbo,
I'm not asking about the body tail lights. I'm asking about the single high mount brake light that is fitted in the top of the large barn door.
Maybe altech bulb has blown?
Hi Yendor, all globes are working , the bottom ones on bumper where led and incandescent bulbs have replaced them . Now cruise control working again cheeers Alex
6th February 2016 11:25 PM
15th April 2017, 04:24 PM
Hi All, Ive had the same problem with the cruise control on my 98 tb45. I get the CC light in the switch but no joy when i try and set the speed.
i have checked brake light bulbs and fuses. I don"t know if it was coincidence(probably was) but about the same time it stopped working i had just replace the clutch slave cylinder..i Have checked the sender on the brake pedal . I really miss cruise control. any helkp from the Brains trust would be very much appreciated.
