7th January 2016, 09:32 PM
#11
I don't seem to have enough space there Westy.
The hand-grip on the roof bar mount and the black plastic cover on the roof bar end restrict the space to mount the light.
I will give it another try anyway, never hurts to make sure twice.
The Following User Says Thank You to MyGU8 For This Useful Post:
BigRAWesty (7th January 2016)
7th January 2016 09:32 PM
7th January 2016, 09:34 PM
#12
Yea now looking at the pics it does look a bit big..
What about flipping them and grabbing a slim line 6" work light / bar from led light co. Same out put as the double row ones but much slimmer..
8th January 2016, 11:09 AM
#13
If you type roof rack brackets on Ebay you will find hundreds of different shaped brackets
http://www.ebay.com.au/sch/i.html?_f...acket&_sacat=0
8th January 2016, 07:33 PM
#14
Something like this may be better and use your other ones maybe on a pole around camp
http://www.ebay.com.au/itm/OZ-FOG-2X...AAAOSwKrxUY7ie
http://www.ebay.com.au/itm/2x-20W-LE...IAAOSwEgVWRSFY
20 watt would be the highest Id go ,
you'd get plenty of hours from your Aux battery
The Following User Says Thank You to threedogs For This Useful Post:
8th January 2016, 07:49 PM
#15
Just did a quick installation. Not sure whether I like it or dislike it.
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
8th January 2016, 07:53 PM
#16
Is it solid,, sticks out a tad eh is that what you see ?
8th January 2016, 07:58 PM
#17
Yes it is super solid TD. May be because I know that I did that or because as you said TD, it does stick out a bit.
I think I liked my mock up setup better (previous photos).
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
8th January 2016, 08:16 PM
#18
http://www.ebay.com.au/itm/171274323...%3AMEBIDX%3AIT
These bits slide inside the rack and with a bit of flat steel should hold the light nice and tight
8th January 2016, 09:20 PM
#19
Yep, that's what I am using TD, finally I think I am settled on this one;
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
threedogs (9th January 2016)
10th January 2016, 04:24 PM
#20
Some changes again...
Before: (too many exposed nuts and bolts):
Now:
2012 CRD:
DIYs;
RedArc Dual battery
Hifonics audio amp
Reverse camera
