Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Crd fuel pump at 90 thou
    43 Post(s)
    I still call bollocks...
    and if someone tried to charge me for changing a timing belt on a ZD30 it would be Hi Ho Hi Ho it's off to the ACCC we go... mainly cause they don't have one
    Are they chain or gear like the old td?
    Patrol Guru Rock Trol's Avatar
    Mar 2013
    NE Melbourne
    I've got a 150k on mine and no work done to it.
    With common rails you don't do any servicing on the pumps or injectors unless there is a problem. I have had a Diesel mechanic tell me that. The pumps are not as complex as the Di's because they don't meter out the fuel. They just vary the pressure as needed. Fuel metering is handled by the injectors. Any work on them would have to be done in a sterile environment with filtered air to get rid of dust and the techies wearing masks etc. Not something that can be handled by a local diesel shop.
  4. The Following User Says Thank You to Rock Trol For This Useful Post:
    BigRAWesty (3rd January 2016)
  5. #13
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    Nissan have capped price servicing:
    http://www.nissan.com.au/~/media/Fil...rol%20Y61.ashx
    Jack
  6. The Following User Says Thank You to jack For This Useful Post:
  7. #14
    Dec 2016
    Townsville
    Just checked my Manual does say Timing Belt.... I was sure these don't have a belt..... Must be getting old now i'm paranoid because the 100K hasn't been stamped..
  8. #15
    43 Post(s)
    Quote Originally Posted by Grumpygnome View Post
    Well they are chain lol..
    Seen a few of late being done.
    Dec 2016
    Townsville
    Phew was starting to second guess mysef lolol.... was thinking crap i've done my homework befor getting one gu7 has majority of the bugs ironed out... went had a second look at the book to realise it hasn't had the 100 stamped..
