Results 1 to 9 of 9
Thread: Erg cross over pipe Blown and have Egr blocked . . . Can I .......
    Advanced ImRobboToo's Avatar
    Sep 2015
    Great Southern, Western Australia
    Block the Egr on the manifold side. ?? I'm stuck in the Outback WA At the moment and wanting to know so io can continue home. End of Holidays and meant to be home Sunday.
    Any help ASAP would be greatly appreciated
    Arguing with a Zealot, is only slightly easier than tunnelling through a mountain with your forehead !!!
    Have you blown the EGR cooler pipe????
    Have you lost coolant??
    Sep 2015
    No mate. It's the pipe going across the back of the engine block to the Egr . . . . We found we can MIG it up for now. If that fails, can I block it from the Manifold ?
  5. The Following User Says Thank You to ImRobboToo For This Useful Post:
    BigRAWesty (2nd January 2016)
    43 Post(s)
    Quote Originally Posted by ImRobboToo View Post
    I would block it at the manifold. You'd be loosing exhaust Gass out the hole instead of going threw turbo
    Sep 2015
    Ok cool. We are putting the Mig on it now and seems to be holding so hopefully we won't need to block it.
    Tapping it out . . .
  8. The Following 2 Users Say Thank You to ImRobboToo For This Useful Post:
    BigRAWesty (2nd January 2016), threedogs (2nd January 2016)
  9. #6
    Yes you can block it at either or both ends.
    Most people only put the plate at the RHS because it is easier to access
  10. The Following 2 Users Say Thank You to the evil twin For This Useful Post:
    BigRAWesty (2nd January 2016), ImRobboToo (2nd January 2016)
  11. #7
    Sep 2015
    Alls well that ends well. Glad the Mechanic was a boiler maker in a previous life Patched it up stronger than it was, and I'm now 6 hrs down the road. Another 8 hrs tomorrow and will be home. Thanks to all that posted so quickly. I was making a plate up as he did the welding (just in case and I could install it on the side of the road if the weld failed) Heading to the pub now as I think a well deserved drink is needed.
  12. The Following 4 Users Say Thank You to ImRobboToo For This Useful Post:
    AB (2nd January 2016), BigRAWesty (2nd January 2016), growler2058 (2nd January 2016), the evil twin (2nd January 2016)
  13. #8
    Feb 2011
    Shed
    45 Post(s)
    Excellent mate. Definitely worth a beer or 3
  14. The Following User Says Thank You to growler2058 For This Useful Post:
    ImRobboToo (14th January 2016)
  15. #9
    43 Post(s)
    Good outcome
  16. The Following User Says Thank You to BigRAWesty For This Useful Post:
