27th December 2015, 04:33 PM
What size mig wire should I get?
I have a Cigweld Mig 135 here and I need to get some wire. I have a gas bottle here to use and was using 0.8mm gasless wire, before getting the gas.... MY local shop has 0.6mm or 0.9mm gas wire. It will be for general purpose welding, your usual RHS and angle iron type stuff. If i get the 0.6mm this might be better for real light stuff like panel etc, but maybe not so good for general steel welding. Not sure on this....
Cheers.
Mark.
27th December 2015 04:33 PM
27th December 2015, 05:39 PM
I use 0.8 for everything. It's fine for 1.6mm exhaust pipe or 10mm thick plate.
If I had something really thick to do I'd just swap the roll to 0.9 but I can't remember the last time I had to do that.
John
The Following User Says Thank You to jff45 For This Useful Post:
mudski (27th December 2015)
27th December 2015, 05:47 PM
I would be more inclined to go 0.9 over 0.6. Maybe try a different place to get 0.8. It's pretty common.
1999 GU DUAL FUEL 4.5 - 2" OME - 33's KM2s - SNORKEL - CUSTOM DINTS.... Goes by the name Candy (the car not me
The Following User Says Thank You to lhurley For This Useful Post:
27th December 2015, 06:25 PM
If your gun and liner are suitable for 0.9, using 0.6 in it will be annoying. It's like the proverbial .... in a shirt sleeve.
I bought a Parweld gun for max 0.8 and it's really good. I have to switch guns if I want to use 0.9 now.
John
27th December 2015, 10:12 PM
jff45
I have the same welder, will run 0.9, even 1.0. I however only run 0.8 in mine as it was most suited to my application.
27th December 2015, 10:28 PM
The welder is a Unimig 240 and the original Unimig gun will take 1.0mm which makes the 0.8 sloppy in the liner.
The guns have Euro plugs so easy to switch over.
John
27th December 2015, 10:38 PM
jff45
I can switch tips in the gun to suit the wire size if this is the same thing...
if 0.8 is better i will see if i can get it from another shop. But if i cant?
28th December 2015, 09:01 AM
Not the same thing. The tip must match the wire anyway.
If your liner is too big for the wire size, you can pull the wire in & out 10 - 15mm and this can give you erratic wire feed.
I found Cigweld 0.8mm wire at Masters.
You can also use your 0.8 gasless wire with gas as well. I'm told it gives pretty good welds but I've never tried it.
John
mudski (28th December 2015)
28th December 2015, 10:08 AM
I use .9 and it does the lot just adust the feed and amps for thinner material
28th December 2015, 11:36 AM
mudski
Most tool shops sell it. Google some local welding supply shops too.
