Results 1 to 7 of 7
Thread: Need wire diagram for GU zd30 CRD (2010) for ECM
    Dec 2015
    Hi Guys, I am chasing a ecm/ecu wire diagram to sort out my patrol GU. Has a U1000 code and auto box not shifting correctly. Wiring has been tampered with, I just want to check continuity of the wires from TCM to ECM.
    Thanks in advance. George
    Bumped , maybe ET or Yendor may be able to help you out.
    If you just want to test the ECM relay you can swap it with the Aircon
    for test purposes
    Patrol Freak jff45's Avatar
    May 2012
    Morayfield, QLD
    13 Post(s)
    If you want a copy of the AT.PDF from the service manual, PM me your email and I'll send it. It has circuit diagrams and testing procedures..
    John
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Just go to the intro section and welcome some new members until your post count reaches 25 then you can download the CRD manual here
    http://www.nissanpatrol.com.au/forum...-with-CRD-info
    Is your auto/wiring from a DI?
    U1000 is a can communication fault.
  6. #5
    Dec 2015
    Hi guys, thanks for the info. Found what I need from a guy (grosjean.pierre) where I found a GU workshop manual Supplement X which has all the info I need. Can't believe how many workshop manuals there is for the GU.
    Not fixed yet but just need to check continuity of all wires to TCM and remove code U1000.
    Thanks George
  7. #6
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by jok06 View Post
    Thanks George
    Yes there are numerous websites that you can download it from. You can also purchase a disc on Ebay for around $10...
  8. #7
    nice tip on using the Aircond
