Results 1 to 8 of 8
Thread: Wiper & washers staying on
    Oct 2014
    Sedgwick Victoria
    Hi all
    Driving home from the shop yesterday and my wipers & washers came on by themselves, had to pull the fuse to stop them, I've read a bit on here, now thinking it could be wiper amp module. Vehicle is a 12/2008 GU TI wagon, trouble is I can't find where the module is located. Anyone tell me where it is pic would be great I've looked on the inside guard near the batt no luck, thanks
    175 Post(s)
    G'day mate. This happened to my CRD 2009 GU as well. From memory Nissan replaced something called wiper amplifier ? somewhere behind the covers near the battery... When mine turned on, by them selves I heard continuous clicking under the hood, and pulled the fuse.
    Nissan fixed it under warranty, so I don't know much about it, or how much it costs etc.....
    This is as much as I remember as this was way back in early 2013.
  4. The Following User Says Thank You to Hodge For This Useful Post:
    Semmo (19th December 2015)
    Advanced ForgeCreekFerals4x4's Avatar
    Dec 2015
    VIC
    thats the opposite to mine, which have decided not to work at all haha
    Assuming I'm like most other girls is your first mistake...
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    The wiper amp in the GUs is part of the wiper switch.
    A short to ground in the Blue wire with a Yellow trace that runs to the washer bottle pump will also cause both the washer and wipers to come on by themselves.
    ForgeCreekFerals4x4 have you checked for a blown fuse?
    Oct 2014
    Sedgwick Victoria
    Thanks Yendor I will check that out, sounds like I need a new switch.
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    i had rats chew through this in my gq. i rewired it. grrr rats...
    check the wires first its the cheaper fix
  9. #7
    Caboolture, QLD
    While on the subject of wipers, my front wiper water pump wont work. Rear one is fine. Any ideas? No I haven't looked at the destruction man-ual.
    Are you ready for Christmas?
  10. #8
    43 Post(s)
    Patrols run 2 seperate pumps..
    Un bolt the tank, swap the stuffed pump out and re fit
  11. The Following User Says Thank You to BigRAWesty For This Useful Post:
    Oversize (15th January 2016)
