Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 73
Thread: GQ Fixing...
  1. #61
    Patrol God mudnut's Avatar
    SW Vic.
    80 Post(s)
    Where exactly is the 3/8 hose?
    Advanced
    Dec 2015
    Did that work?
    Anyway, that's the fuel hose I've jammed on to for now (not that it does much at the moment, most of my brand new coolant is all over the ground), it goes from below the bleed screw to the intake manifold.
  4. #63
    SW Vic.
    80 Post(s)
    Maybe just a short term solution.
  5. #64
    Advanced
    Dec 2015
    On what grounds?
    Getting the "correct" hose is no drama. I am just curious what the difference is, I can't seem to find a straight answer.
    I've heard of fuel turning the incorrect hoses tacky, which I guess is fair enough. Is there a reason I can't use any given hose for coolant?
    It says 10 bar on it, so I guess it has some kind of pressure rating.
  6. #65
    SW Vic.
    80 Post(s)
    I would think that coolant and fuel act differently to the types of rubber that are used. I used to smear any grease I had on the connections of the water hoses, until it was pointed out to me, that grease is a hydrocarbon and will make the coolant hose rubber deteriorate. I now use a food grade grease on all of the coolant system joints. The coolant will be at around 100 degrees, so that may cause the fuel hose to harden, maybe.
  7. #66
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    I just use a very thin layer of silicone on coolant hoses. Yeah, I reckon vaseline is probably better than normal grease.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
  8. #67
    Patrol Freak garett's Avatar
    Jan 2015
    south of the boarder
    19 Post(s)
    for coolant hoses the best grease i've used is lube, its water based so no damage to coolant hoses.
  9. #68
    38 Post(s)
    Quote Originally Posted by garett View Post
    lube? Where do you buy that from?
    Cheetah Outreach
  10. #69
    Jan 2015
    19 Post(s)
    the adult shop......
  11. #70
    38 Post(s)
    damn...........
    Cheetah Outreach
