16th December 2015, 11:46 PM
#21
I don't think it's the self test as the gauges have changed before I actually start the car. If my main tank is almost empty and the sub half full I can see a drop of around 1/8 of the sub tank in a couple of days (have a work vehicle so Patrice may sit dormant for a couple)
Now you mention it mud runner both tanks make a hiss when the caps are removed but I've never really taken note of whether it's positive pressure or a vacuum, usually to busy staring at my nissanpatrol.com.au sticker.
Please excuse my silly questions but where might I find the breather tubes? Do they come straight off the top of the tanks as I may extend them somewhere a little higher to prevent s#*t getting in.
Will definitely take not of what happens when I remove the caps next time....
2000 GU, TD42T, bullbar and roof racks, 2inch lift, winch, front and rear air lockers, 3inch Scotts rods dump and exhaust kit.....more to come!
16th December 2015 11:46 PM
9th February 2017, 12:19 PM
#22
Digging up a really old thread but ..............Hiss good, no hiss bad !
My New LRA main tank fitted by TJM Darwin developed a nice leak from the top after I got back home to Canberra. The problem was the way the fuel hoses were fitted, they kinked and rubbed a hole through one line, thus leak. Now the last fill before I noticed the leak I distinctly remember hearing no hiss when I removed the filler cap, thought it strange at the time, I assume that air was entering back into the tank via the holed hose (fuel return hose I assume).
TJM Canberra fixed the problem, no charge, and confirmed that he fuel line had been routed the wrong way, rooted is what I thought.
So, my take away from this is if no hiss maybe an issue with the lines into the tank
9th February 2017, 12:26 PM
#23
A good bit of PR for them. I often judge companies by how they react when it all goue wrong rather than by their advertised quicker, better, cheaper touts.
Glad they fixed it and you are 100% go again.
The Following 2 Users Say Thank You to 4bye4 For This Useful Post:
Bigcol (9th February 2017), Cuppa (9th February 2017)
9th February 2017, 09:19 PM
#24
hiss is good
you have a sealed tank
you have a mechanical pump sucking fuel into engine
open fuel cap - air rushes in
good sign
10th February 2017, 09:04 AM
#25
Dumb Hodge question time ... But... If there is a hiss when undoing caps , doesn't that mean breather is blocked somewhat ?
If the tank only takes a breath when undoing caps , what purpose does the breather have ?
Both my tanks hiss . When Cuppa originally wrote this thread I was always meaning to check my breather. Forgot about it.
10th February 2017, 09:15 AM
#26
Hodge
Yeah both mine do too. Both breathers on my tanks are clear though. Im wondering if this is normal as our Commodore does the exact same thing.
