14th December 2015, 09:50 PM
Moderator
threedogs
Yeah not sure i would buy that though.... I have an Albright which is what the Comp guys use and it about $180. Works great.
In terms of Bench Testing i have not had a look at that Jeep Link but if you google Bench Test winch motor you will get the sequence. Easy to do. The Solenoid acts like a Relay and is a Step up system so the 400amps don't hit your switch and battery.
Check out my Toy -->
Rogue Dung Beetle
14th December 2015 09:50 PM
14th December 2015, 11:01 PM
MudRunnerTD
Ah the wonders of Google!
Cheers for the info and I'll look into this Albright setup if it is the solenoid box that's shagged.
2000 GU, TD42T, bullbar and roof racks, 2inch lift, winch, front and rear air lockers, 3inch Scotts rods dump and exhaust kit.....more to come!
