Results 1 to 10 of 12
Thread: Warn winch dramas
    Advanced Potsy's Avatar
    Jan 2015
    Adelaide SA
    Warn winch dramas
    Noticed that my winch cable was back to front the other day so rolled it out only to find that it will not drive the right way (anticlockwise if standing on the passenger side) the other direction is fine which tells me the motor is ok but when trying to run it the other way all I hear is a click (maybe a solenoid) from the control box behind the bull bar so maybe the switch that reverses the drive is buggered?!
    Is anyone familiar with these winches and can shed some light on what to look for as I'm hoping I can fix it without having to pull the thing out and drop it into the (more than likely expensive) professionals.
    Cheers people.
    2000 GU, TD42T, bullbar and roof racks, 2inch lift, winch, front and rear air lockers, 3inch Scotts rods dump and exhaust kit.....more to come!
    Are you using the standard warn control box? Big black plastic thing? If so then you have 4 solenoids in there, 2 for each direction. I'd say they are knackered. I'd be inclined to swap it out for a single solid state one. It might not be your problem but likely is.
    How old is the winch? How long has it been on the car? Have you ever services it? I'd take it off and bench test it without the solenoid to make sure it is ok though. Could have water in it which it won't like at all.
  4. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Hodge (14th December 2015)
    Jan 2015
    Adelaide SA
    Cheers mud runner.
    The history of the winch is unknown to me, I purchased the car about a year ago but I know the winch has been on there much longer, am spewin I didn't realise when I bought the car but I never actually planned on keeping the winch a and was way to excited at the time.
    I will more than likely pull it out later this week with my cousin and see if we can test it.
    When you say test it without the solenoid box is it pretty straight forward (I.e. One active, one forward and one backward) cable out of the winch? And all I need to do is bridge these.
    Also the solid state control box, is this an aftermarket accessory or is it just a newer setup made by warn?
    @ MR do you have a link for that solid state controller ??
  8. #5
    175 Post(s)
    This as well I'd like to see how it all works.
    Tapatalked from S6
    http://www.ebay.com.au/itm/Giantz-12...oAAOSwA4dWH3Ce
    I think these are the solenoids in question
    not sure if these are the best quality out there
    as pricing varies a bit
  10. #7
    Quote Originally Posted by Potsy View Post
    Cheers people.
    As others mention... I would start with a Winch service IE pull it out and check brushes, regrease etc etc.
    Warns will 1/2 fill with goo if they are not installed correctly IE had the motor drain orientated properly
    I know that isn't the problem but would do it anyway.
    Pull the cover off the controller and check all wiring.
    It wil probably be corroded and/or full of crap.
    You will possibly have probably a faulty solenoid in one of the pairs
    Approx $60 each to replace if you want to keep the original setup
    Warn use solenoids in pairs to prevent uncontrolled overruns so probably only need one
    The 4 point contactor style are a popular replacement but be aware that most are cheap and are NOT solid state
    They have moving parts sama sama as the Warns just 1/2 as many of them
    A solid state controller that handles that amperage is hideously expensive by comparison
  11. #8
    Jan 2015
    Adelaide SA
    Cheers all for your input,
    evil twin, i will pull it out and leave it on the bench for a while to play with.
    Are the brushes easy enough to remove and clean?
    Also am going to try and bench test it as recommended by mud runner but am wondering if anyone knows of any wiring diagrams for the two solenoid setups?
    I'm sure it won't be to tricky to work out but I love a good diagram as I'm a fridgie but automotive isn't my cup of tea!
    Maybe the missus will get me a new one for Christmas......hahaha.
  12. #9
    Here ya go, apols that it is from a Jeep Forum but at least they are good for something http://www.jeepforum.com/forum/f12/w...iagram-515718/
  13. #10
    Jan 2015
    Adelaide SA
    Thanks mate, trust a jeep forum to know all about winches!
    I saw a new one the other day and they come factory with swanky red recovery points on the front.
    Should make everyone's life easier.....teeheehee.
