8th April 2011, 04:52 PM
If the choke butterfly can be moved as you say then the shaft is not seized.
Have you checked the choke butterfly position when the engine is completely cold?
Tony
8th April 2011 04:52 PM
8th April 2011, 05:04 PM
I did this quick check when the engine was moderately cold, I'll give it a quick check in the morning. I've got a feeling its permanently stuck in the half open position regardless of the temperature...
Update:
Given it another quick check and the choke butterfly moves around normally until I touch/pump the accelerator after which it gets stuck in half open position and have to push it hard til it clicks and then it moves freely again, touch the accelerator again and its stuck in half open again. Spring busted or something?
Would installing a manual choke fix this problem permanently too?
Cheers,
Ted
10th April 2011, 05:43 PM
just a quick bump,
you still out there tony?
10th April 2011, 05:45 PM
21st April 2011, 02:27 AM
RIP - valued member and true gentleman of this forum that will be missed by many!
I'd be interested to know what manual choke system works for the TB42, as mine gives problems in Brisvegas, and even more when I go to the New England area of NSW where it hits -11C.
I have marked the butterfly adjustment so I have reference point to come back to, and rotated the external housing to get the butterfly to close earlier or later. However I think I also need to pay attention to the instructions for fast idle too???
I used to regularly give it all a good squirt with carby cleaner but have been a bit slack lately. Mine must be coming off a bit too soon as it leans out and backfires through carby when it's gone a k or so from cold. Not a fuel filter issue as it responds well to a boot full up a hill when warmed up.
Mechanic mate over the road also has TB42, and in common with other cars he has owned over the years, has removed the choke entirely.
21st April 2011, 06:33 PM
Yeah mate I've had a mechanic look at mine and its not the choke, which works perfectly fine rather its carby problems for me.
Previous owner I bought the car from hadn't connected the carby and pollution lines properly so I've just connected em back up but am not sure if this has been done properly.
Am kind of hoping there's someone with a 1990's model GQ with a TB42 Carby so I can see how they're supposed to connect up so I can just copy that, AND living near Newcastle NSW...
