8th April 2011, 11:04 AM
Engine REALLY doesn't like cold start...
Hi guys,
Some help needed, every time I start the engine in the morning it really doesn't enjoy the cold start. Revs will be really low and struggling not to stall, it'll run at say 200 revs or less until the temperature comes up.
Which has me thinking there's something wrong with the automatic choke, however when the engine begins to warm the revs start to increase and once warm she idles perfectly and purs at me again running smoothly at exactly 650 revs and never misses a beat!
What gives?
Cheers,
Ted
8th April 2011 11:04 AM
8th April 2011, 11:23 AM
Banned
Ted
Hi guys,
What gives?
Cheers,
Ted
Have you cleaned the MAF sensor? Something simple to try, but mine was doing the same after the last trip, and ended up giving the sensor a hit with some CRC mass air flow spray, and hey presto!
8th April 2011, 11:52 AM
Mines just like that too, except I have a manual choke which I pull out until warm otherwise the truck shakes like Sh!t or stalls lol I possibly thought the glow plugs arn't as good as they use to be and may need replacing, It's on the "I'll get round to it list" haha
If you fix yours please post the solution
Brett
8th April 2011, 12:02 PM
SPAMINATOR
HippoNZ
Brett
Is that TD42? mine was doin the same but started running a fuel additive to clean the injectors and its fine, on a real cold morn it'll shake and rock n roll a bit without help from the "choke" but hell of a lot better than it was
8th April 2011, 01:39 PM
Have been looking around a bit and indeed its the automatic choke stuck open (Choke off)
Take off the air filter housing and you can see if the "butterfly" is stuck open or closed.
Will wait for the car to cool down again and will give it another try and see if it closes, if not I'm pretty sure its dodgy and I'll just turn it into a manual choke. I've recently changed all my spark plugs etc, so I reckon its a reasonably easy fix!
Cheers though fella's!
8th April 2011, 01:58 PM
growlers71gq
Sure is a TD42, I ran a fuel additive last week on trip I did, still on the same tank of fuel. You reckon I should keep doing this for a while to see if it cleans out the injectors? TD42's are a big solid motor so I expect a bit of shake but you could almost charge 5yro for a roller coaster ride! LMAO nah shes not that bad but not that good either. cheers growler
8th April 2011, 02:03 PM
Ted, when you do a cold start do you pump the accelerator once before you start the engine? A lot of automatic chokes need that to reset them to the start position.
Tony
8th April 2011, 03:07 PM
Yeah mate i always give the throttle a little kick when i turn the ignition, heard that little nugget of info before, cheers tony
8th April 2011, 03:34 PM
When the engine is cold remove the air cleaner housing and have a look down the top of the carby, the choke butterfly should be closed. You may need to open the throttle once to release it to the closed position. If the choke butterfly is not closed have a look at the choke coil housing on the outside of the carby, there should be lines that line up between the choke housing and the carby body.
If it's lined up but still stuck open then it could be either a siezed butterfly shaft or no power to the choke coil.
Tony
The Following User Says Thank You to YNOT For This Useful Post:
8th April 2011, 04:27 PM
Hey tony,
given it a once over like you said mate, everything is connected up properly, the carby and all lines up the way it should be (had this checked out by a mechanic)
However the butterfly is stuck half open, with the engine running i gave it a little push to close the choke butterfly and the engine shut off.
When i turn the key again to start it, it returns to half open position. It wont stay completely open nor will it stay completely shut either, any ideas?
