Page 5 of 5 FirstFirst ... 345
Results 41 to 46 of 46
Thread: Time's GU IV 4.2TD
  1. #41
    Jul 2015
    Victoria
    All you need is a minigun on the roof and you've got yourself a tank xD Nice!
    Patrol Guru TimE's Avatar
    Canberra
    3 Post(s)
    Cool
    Picked up this little beauty on Tuesday, makes the old Kimberley Kamper look like a swag
    Off up to the Gulf, Arnhem Land, all the usual NT Parks, Ayers Rock and home via the Oodnadatta Track and the Flinders from ANZAC day to early September, the joys of retirement
    It is a Vista RV Crossover XL
    PS Will change the sig pic (which was taken on the Oodnadatta track) when I have a similar pic of the new toy on that track
  4. The Following 8 Users Say Thank You to TimE For This Useful Post:
    BigRAWesty (11th February 2016), Hodge (11th February 2016), Kimbo63 (11th February 2016), mudski (11th February 2016), NissanGQ4.2 (11th February 2016), nissannewby (11th February 2016), Stropp (12th February 2016), Woof (11th February 2016)
  5. #43
    Canberra
    3 Post(s)
    Well the big trip is over. 17,000ks of rough stuff and fun.
    R&M The long range fuel tank developed a fatigue crack at one of the baffle welds, crack welded at Birdsville but opened up again at Coburg. Fix was a new tank in Darwin. Shocks finally gave up the ghost coming into Alice Springs, so new set of ARBs fitted there.
    When doing long trips I budget a $ per k to cover everything (food, drinks going out for meals, park fees etc) and allow a contingency for repairs etc. This trip used up all the contingency
    After arriving home, and major service, I notice a "funny" whining noise when under load, clutch in noise goes away, sort of sounded like transmission whine. Mechanic takes out rear tail shaft and goes for a run on the front diff, no noise. Diagnosis is rear diff, will need a bearing kit as minimum, plus check and adjustment etc, about $1,000 give or take. So given that the diff is out and it could end up costing more, the decision is taken to stick in an elocker (to match the front one) Due to get done next week.
    Hopefully the last of the repairs for a while!
  6. The Following 4 Users Say Thank You to TimE For This Useful Post:
    Clunk (29th October 2016), gubigfish (29th October 2016), MudRunnerTD (30th October 2016), Stropp (29th October 2016)
  7. #44
    Dec 2015
    Maidstone UK
    Hi from the UK
    I say jolly nice truck - what he says in OTT english accent
    but seriously love it
    I have a td42 imported from Japan
    it doesn't have an intercooler on it but i guess yours does by looking at the bonnet
    would it be cheeky to have a photo of the underside of the bonnet and of the intercooler
    I am about to order an intercooler kit and i was thinking of using a ZD30 bonnet
  8. #45
    Canberra
    3 Post(s)
    Check this YouTube video, exactly the same as mine
    https://youtu.be/MvRsFTIDB78
  9. #46
    Canberra
    3 Post(s)
    Put together a bit of a "blurb" for a presentation I did on the Patrol at the recent 4WD Spectacular in Queanbeyan, here is a precise of my "bits and pieces"
    2005 Nissan Patrol GU IV ST set up for remote touring and the occasional tough weekend trips.
    ENGINE
    Factory 4.2l TDI diesel, turbo and intercooler
    'Tuned' turbo
    3” dump pipe and exhaust
    Tuned for torque
    SUSPENSION
    2” lift with Ridepro springs and OME shocks
    After market sway bar link extensions
    BOSS rear spring tower brace kit
    WHEELS & TYRES
    17X8 Nissan Factory Alloys
    Mickey Thompson ATZ P3 285 X 70 X 17 tyres (LT)
    Under bonnet ARB air compressor for tyre inflation
    TRANSMISSION
    5 Speed manual. High and low range transfer case
    43% reduction gears on low range (Marks Adapters)
    Diff Ratio 3.9:1
    15 cog gearbox speedo cable to correct speedo reading (larger than standard diameter tyres, 33”)
    Front and rear Eaton eLockers
    BODY MODS
    Nissan (ARB) Bullbar, with mount for 3m Sand Flag
    ARB side steps and brush bars
    Kaymar rear bar with twin wheel carriers and 3500kg tow hitch
    Rated recovery points front and rear
    Tradesman Roof rack with shovel and hilift jack holder and side and rear awnings
    Long Range Fuel tank 146l, plus 30 l Factory Aux tank
    ELECTRICS
    Triple battery – AUXs 2 X 105 a/h AGM battery with 'smart' isolator, 900CCA starter battery
    300W 240volt pure sine wave inverter
    Projecta 15amp battery charger
    Anderson plugs for Inverter, Fridge, camper trailer
    2 X Roolite Driving Lights
    2 X Projecta 120W folding solar blankets
    COMMUNICATION
    80 Channel Icom 410 UHF
    80 Channel Uniden 8060NB (used to scan)
    Bluetooth linked to car stereo for handsfree phone
    Globalstar Satellite phone with car kit
    NAVIGATION
    Samsung 10” Tablet on RAM mounts Running Ozi Android
    Laptop running Oziexplorer used for map storage and track planning
    1:25,000, 1:250,000, 1:1,000,000 topo maps and Hema Desert Maps
    5” no name GPS running IGO 8 and Ozi CE software
    Paper maps and Atlas
    INTERIOR
    First Aid kit
    ORS drawer system and fridge slides
    Milford full length cargo barrier
    Middle row seats replaced with shelving
    Fire Extinguisher
    Black Duck canvas seat covers
    Rear cargo area window sun screens (Solar Screen)
    50l Waeco Fridge on slide
    37l Engel Fridge (used as a freezer) on slide
    Reverse camera
    TPMS
    RECOVERY
    Warn Tabor 9000lb winch
    Snatch Strap
    Snatch block
    Tree trunk protector
    Winch extension strap
    Long handled shovel
    various Bow Shackles
    Gloves
