11th December 2015, 11:12 AM
Cracked Coil Towers?
I've noticed that my GU Patrol wagon leans a bit to the right, I originally thought it might be the coils have sagged unevenly but now I'm wondering if the coil towers are cracked. How can I tell, and what should I look for?
WARNING: Using a Tow Ball on any Snatch can KILL PEOPLE!
11th December 2015 11:12 AM
11th December 2015, 11:27 AM
Grab a torch and have a good look around that top plate, should be very visible IMO
Most will sag to the right as thats where you sit,
coils are different lengths to compensate for this.
11th December 2015, 11:46 AM
JME_GU
A crack in your coil tower mate. Sorry had to be said. Grab a torch and have a gander. If its cracked that much your car has a lean. You will see it.
11th December 2015, 01:04 PM
Heres one image Ive found,,,,https://www.google.com.au/search?q=c...jN7C5pve7oE%3D
How old is your suspension ????
what type of driving do you do.????
11th December 2015, 01:26 PM
They usually tear off the chassis. But if the lean is that bad and you have no loud banging noises when driving I'd say it's springs.
I doubt you'd notice a cracked tower bracket by the veichle height unless it's parted ways or is extremely bad..
12th December 2015, 08:20 PM
The welds between the chassis and brackets seem fine, there is plenty of room between the top of the brackets and the floor of the shell, everything seems fine. Maybe it's just the springs?
12th December 2015, 10:41 PM
Legendary
JME_GU
You probably already know this, but uneven ground can sometimes make you think that something is wrong, as a front wheel down in one corner will cause the opposite rear side to look like it is higher. Always check for spring heights on flat ground - Patrols usually have longer / taller springs on the driver side to compensate for the weight of the driver and second fuel tank too.
12th December 2015, 10:43 PM
Legendary
Your spring towers would seem to be OK too, if they are sitting parallel with the body floor above ( even gap the whole way across the top of the tower ), so you can definitely discount these as an issue
10th February 2016, 04:42 AM
I'm worried about mine. 29,000km on it, over 3t daily.
Only running 250kg constants in the rear though. I ordered the Boss coil braces, just need to install them.
The Following User Says Thank You to farqman For This Useful Post:
BigRAWesty (10th February 2016)
