Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: Stabaliser or not
    Patrol God wildgu6's Avatar
    Sep 2010
    Adelaide S.A
    Stabaliser or not
    Hi guys, dumb question time. Last trol I had, had no front stabiliser bar, new trolls got a beefy bar on front.
    Not convinced with handling off road, old trol was killa off road.
    My question is do I need a stabaliser on the front or not, what are the alternatives?
    What is involved with disconnectable sway bar links, are they worth it and is it a hassle to disconnect/re-connect.
    Who's got what and what are your thoughts.
    Cheers Pete
    "Tonka Tuff" 08-GU6, 3.0lt crd, 5 Speed, Turbo Diesel, Hpd, Arb, Ome, MT Baja Atz.
    You can buy quick disconnect swaybars try Superior engineering, Michael will sort you out.
    They are required for a RWC. Ill find a link for you
    http://www.ebay.com.au/itm/Front-Swa...4AAOSwWnFV-TMy
  4. The Following User Says Thank You to threedogs For This Useful Post:
    wildgu6 (8th December 2015)
    Sep 2010
    Adelaide S.A
    Cheers TD, they look easy enough, but after a day of play, covered in mud and poop, would they be painful to re connect before heading back on the black top
    I dont use them but MR would have them or maybe Winnie
    201 Post(s)
    Nah not me.
    I have removed my front sway bar and kept the rear in. I only noticed a very small change in the handling on road but a massive difference offroad. I definitely recommend!
    Anyway if you don't like it without them in, it's a 10min job to bolt it back up
  8. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    threedogs (9th December 2015), wildgu6 (8th December 2015)
  9. #6
    Sep 2010
    Adelaide S.A
    Nah not me.
    Cheers bud, like I said, didn't have one on last trol and had no issues, might give it a try on this one, even though I do like the way it handles on the road.
  10. #7
    579 Post(s)
    Quote Originally Posted by wildgu6 View Post
    x2 on Winnie from my experience noticed very little difference on road, the rear however does make a substantial difference and I was lucky to have oem disconnect on rear.
    Having saying all this though the front would make a huge difference if you had to swerve hard emergency left and right to avoid an accident
  11. The Following 2 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (8th December 2015), wildgu6 (8th December 2015)
  12. #8
    324 Post(s)
    I fitted them to my GQ and they are hideous things to reconnect.
  13. The Following 2 Users Say Thank You to MudRunnerTD For This Useful Post:
  14. #9
    Sep 2010
    Adelaide S.A
    Cheers MR, that's what I was afraid of, so what do you run now, or what would you recommend?
  15. #10
    324 Post(s)
    I don't have a front sway on either patrol but have drop boxes on both. I have a extra HD rear sway bar on the GUIV and it's great. Keen to put a rear to the GQ too. If anyone has a late model rear sway bar off a GUIV or later I'd be keen to buy it.
  16. The Following User Says Thank You to MudRunnerTD For This Useful Post:
