Results 1 to 3 of 3
Thread: 2002 4.8 Petrol GU Patrol Transfer Pump
    Jun 2015
    Sydney, Australia
    Hey Guys,
    I have a 2002 GU 4.8L Patrol wagon and the sub tank has died. I have tried unplugging the battery which got it working for an hour or so and also I have run a new earth to the chassis. So I am thinking that the pump must be gone. I believe that these pumps are outside of the tanks and not that difficult to replace? If so, does anyone have one I could buy? It's the worst timing as we are going on a long trip on January 5th and of course all the 4wd servicing places are busy as.
    462 Post(s)
    The pump is located at the front of the sub tank. Behind a metal guard. Easy to remove and refit. Any wreckers should have one, or i assume you could retro fit an aftermarket jobbie there.
    Edit : maybe could run 12v direct to the pump to see if it is the pump and not something else. If that can be done...
    Jun 2015
    Sydney, Australia
    Thanks for the advice. I will have to have a look.
