29th November 2015, 06:41 PM
#21
biggqwesty
Factory temp gauges are a very rough guide. And many don't trust em..
One way to check your secondary gauge is to borrow or buy one of those Lazer temp gauges. When up to temp check your radiator hose near where your prope is..
Top idea mate! Just wish I didn't live so far away from the shops haha. 3 weeks wait on any post!
I've read about factory gauges being a bit off the mark. Would a temp reading of the outside of the hose be close enough to the inside coolant temp?
GQ Patrol, TD42 NA, 33's, Snorkel, 2" inch lift, Dual Batteries, Roof Rack, Awning... Many more to come
29th November 2015 06:41 PM
29th November 2015, 06:46 PM
#22
Yea it should be spot on.. may get some slight variations if it's minus temps of blowing a strong wind
29th November 2015, 06:48 PM
#23
biggqwesty
That will be a good starting point cheers mate. Would be great if its just a dodgy factory gauge!
The Following User Says Thank You to ashmccormick For This Useful Post:
BigRAWesty (29th November 2015)
29th November 2015, 06:53 PM
#24
I'd still investigate the fuel settings.
If its blowing black smoke all the time it's possibly over fueling. That could be pushing EGT's and that would also increase the engine temp.
But yea start with the Lazer temp gauge.
If it is high then maybe look at a tune.
29th November 2015, 07:00 PM
#25
biggqwesty
Thanks mate, yeh I always thought the smoke was a diesel thing, but it seems to smoke quite a lot under load and feels like someone has tried to up the fuel mix to gain more power... Perhaps the poor mans turbo option...
29th November 2015, 07:06 PM
#26
Yea I did when I went 33's.. but not to be. It just loaded it more, more smoke and more fuel used..
Took it back to factory after a few months..
29th November 2015, 07:13 PM
#27
biggqwesty
I will get a diesel mech to look at the fuel! Would try myself but I'm guessing its more of a specialist thing!
29th November 2015, 07:18 PM
#28
ashmccormick
Yea if you haven't touched it then I'd leave for a specialist.
I only did mine as a trial.
The Following User Says Thank You to BigRAWesty For This Useful Post:
ashmccormick (29th November 2015)
29th November 2015, 07:24 PM
#29
ok Ash, you have several questions that need several different answers
Black smoke - yeppers, its over fueling, so some reason most of the TD42's sold in the Territory & northern WA all had the Injector pump advanced..........( mate used to work at Nissan in Darwin in 80s-90's) not sure of the thought process, but it was to overcome the fuel vaporizing issue some had with the SD33's in the MQ's
have a look at that, as this will not help it with running too hot
aftermarket gauge.
get a decent one - electronic, or even an old mechanical one - either either, sounds like the one you have is cactii to the max
factory gauge
these are really just a "sort of maybe could be temp gauge"
about as accurate as a $2 watch
when the needle is at the mark just before HOT - thats its normal hot running temp - approx 105*C
the hot mark is approx 110*C
when its about 1/2 way - thats a normal running temp in cooler climates
as Kallen said, if you can get hold of one of those temp guns and just double check the aftermarket gauge you have, it will help
29th November 2015, 07:45 PM
#30
Bigcol
aftermarket gauge.
factory gauge
Great stuff thanks mate, it looks as though there's a few avenues to head down now. I will look into my gauge temperature and possibly get that replaced and get someone to back off the fuel a little as that might help with heat and economy too.
Cheers for everyones input, good to get an outside perspective on something thats been bugging me for a while!
