29th November 2015, 11:33 AM
#21
Moderator
So what you have there is a solid state solenoid. I have had one on the GQ without any further protection forever. I have now gone to an Allbright but the concept is the same.. That box has glands to stop water ingress so I assume that is how they guarantee the water proof P67. Removing it will void that but personally i would not hesitate but that's me.
If you really wanted to you could run some silicon around the joint of that solenoid for piece of mind.
Check out my Toy -->
Rogue Dung Beetle
29th November 2015 11:33 AM
29th November 2015, 12:03 PM
#22
Yep I've mounted that solenoid next to the battery..
30th November 2015, 12:57 PM
#23
Righto. Only other question I think I have on this note, and I me sure it's been asked a lot lol.
I should be wiring off my crank battery as my second is a deep cycle Correct??
I have always been told to run off second battery so don't drain the main.... But I don't plan to ever use it without the engine running.
I
30th November 2015, 01:14 PM
#24
Moderator
Off your Cranker for sure mate. Thats where your Alternator will work the best. Everything else off your second.
***EDIT. I have moved your thread into the DIY Electrical section for future searches.
Rogue Dung Beetle
BigRAWesty (30th November 2015)
30th November 2015, 04:47 PM
#25
Thought so. Just wanted to check. And cheers. That's probably a better spot for it
