5th February 2016, 08:19 PM
#11
Travelling Podologist
5th February 2016 08:19 PM
7th February 2016, 10:57 AM
#12
threedogs
Make sure which ever tyre you decide on is of LT construction,
I had a great run with BFG all Terrains,
if you can start your trip with fresh tyres all the better
Ditch your HT tyres they will not cut it out bush
HT or LT should be written on the side wall somewhere.
Lower your pressures when you hit the dirt 30psi is a good starting point
Yes going with 5 brand new tyres + one older spare just in case even though it takes up valuable space in tray.
Existing 694's have 80,000k on them with at least 30,000k to go so will put them back on when I get back and save the new tyres for next big trip.
