Results 1 to 7 of 7
Thread: A little overwhelmed, would appraciate some clarification about WLL
    Oct 2015
    Hi all,
    I was looking at buying some rated recovery points for my Patrol GU III.
    I've started doing some research online to get an idea of the price range, but I'm not really sure if the ones I found are rated high enough. They list a WLL of 5 tonnes, and my car will probably end up weighing around 3.1 tonnes. However, I'm not quite sure if I should be adding a buffer..
    Patrol Freak Bigcol's Avatar
    Sep 2010
    Swan Valley Perth
    11 Post(s)
    your WLL - will be determined by things like
    stuck in mud
    stuck in sand
    stuck in water
    etc
    if you fire off a PM (private message) to Threedogs - he manufactures them - and they are a good bit of kit
    Oct 2015
    thanks Bigcol, will do
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by Bigcol View Post
    stuck in mud
    stuck in sand
    stuck in water
    etc
    But give him a few days as he is laid up in hospital ATM.
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    43 Post(s)
    WLL is a working load limit...
    As above, pm threedogs from outback ideas for them.
    http://www.nissanpatrol.com.au/forum...ad.php?t=12616
    Same price as your eBay sets, but uses quality aus steel and he tests the designs to 16+ tones before they get sold..
    WLL is a lifting term and doesnt really have much bearing in snatching 4x4 terms,
    Its the same as SWL , why ppl would want to over rate something the Manufacturer says
    is beyond me.
    My points are rated to tow at your max towing capacity all dat long. but heaps has been written on it
    so PM sent.
    Until someone comes up with a STD it may be all we have.
  8. The Following 3 Users Say Thank You to threedogs For This Useful Post:
    BigRAWesty (22nd November 2015), outback (22nd November 2015), Woof (22nd November 2015)
    Whyalla SA
    Like everyone has said get them of threedogs.
    Also get one per side AND remember to use high tensile bolts.
