Results 1 to 10 of 11
Thread: Weird Noise when turning
    Expert tuckertrucker's Avatar
    Aug 2015
    Far North, New Zealand
    Hi guys n gals
    I've been putting up with this noise for a while hoping it would pass but its just lingering and getting worse.
    So when I'm moving foward and I turn the wheel I hear this squealing noise. It also happens when I'm on an off camber road that makes the truck pull to that side. Basically it sounds like squealing breaks but a lot sharper - and only when cornering as I described. It also comes and goes a bit, as in sometimes its there and others its not.
    I haven't noticed it in reverse, nor have I noticed it when stationary, but that could just be cause I'm not listening for it.
    Any help would be great cause Im about at my wits end!!!
    BTW - 1992 Nissan Safari LWB
    What about when turning the sterring wheel whilst stationary?
    Legendary 4bye4's Avatar
    Aug 2014
    Kingsley WA
    15 Post(s)
    Power steering belt??
    Expert King_ady1's Avatar
    Beveridge, Victoria
    Does it stop when turning at speed? And does it only do it after a certain amount of turning??
    Aug 2015
    No noise when stationary. Its not the belt - not that kind of squeal. And can does it all the time pretty much. When I first take off, stopping, whenever.
    Aug 2015
    https://www.youtube.com/watch?v=dAicnJd6zYE This is exactly the noise I'm hearing. But only when turning - not going straight. And its a little more constant with mine.
  8. #7
    Feb 2015
    It's not the diff is it?
  9. #8
    have you jacked it up turned the wheel to full lock and tried spinning the wheel?
  10. #9
    Wheel bearings
  11. #10
    Legendary happygu's Avatar
    I would say wheel bearings too.
    If you are turning right, and that is when the noise happens - check the passenger side first.
    If you are turning left - check the drivers side first, as the bearings will have extra loading on the outside wheel of the turn.
