Page 38 of 91 FirstFirst ... 2836373839404888 ... LastLast
Results 371 to 380 of 904
  1. #371
    Nice neat job mate, well done.
    mudski (11th June 2020)
    462 Post(s)
    Mudski's High Warn High Mount Rebuild into an ARB GU Bar
    the bar is off to the sandblaster and powdercoaters as we speak. Hopefully have it tomorrow or early next week!
    I replaced the light bar and spottie switches with the new winch switches and got these fancy Narva push button switches, which are smaller, for the other side (RHS) of the dash cowling. As in the GU the area on the RHS of the cowling you cannot fit the usual Carling style rocker switches. God I hope I've done the pre wiring right at the switches...
  5. #373
    22 Post(s)
    t God I hope I've done the pre wiring right at the switches...
    Just bench test it before it all goes together. Use the indicator lamps from the bullbar or something like that for a test load.
    96 GQ coil/Cab
    08 G6eT
  6. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    mudski (26th June 2020)
  7. #374
    462 Post(s)
    Got the bar back from the sand blasters and powder coaters yesterday. Getting thereIMG_3131.jpg
    Came up good except for where I did my hole patch up work. It’s quite obvious, but it looks a heap better now. So I’m not too concerned. Yet.
    I also had all the special washers, and one of the adjuster stops zinc plated. The other stop would not come out so it stayed in the bar.
  8. The Following 2 Users Say Thank You to mudski For This Useful Post:
    Cremulator (26th June 2020), MB (26th June 2020)
  9. #375
    462 Post(s)
    I have the viscous hub apart with radiator out too. Took 4ml of oil out of the hub as it’s constantly locked on. Hopefully this will be enough to let it not be on all the time.
    This is what they look like inside them....
  10. The Following 3 Users Say Thank You to mudski For This Useful Post:
    MB (26th June 2020), MudRunnerTD (26th June 2020), Rossco (26th June 2020)
  11. #376
    194 Post(s)
    Mark, how do you fill the hub, as its split or through a port of some description? How exactly is the shearing action achieved in the coupling and do you know if the liquid acts like some sort of balancer on the front of the water pump? Interested to understand how the fluid flows around inside the unit. BB can up really good I think also, well done.
  12. #377
    462 Post(s)
    To fill the hub, there is four bolts holding the two halves together. Remove the bolts then let the hub sit with the mounting flange facing upward and let it sit for a while to let the oil go into the other half of the hub, split the hub in half and that pictured above is exactly how you see it wen first opened. Except without the blue silastic everywhere, This hub has been opened many times.
    So how the hub works is....Watch this actually. Its really well explained...
    https://www.youtube.com/watch?v=UwM4OqsLek4
  13. #378
    194 Post(s)
    Thanks mark, bit clearer than the other couple of youtube clips I watched. Its not dissimilar to a drive fluid coupling I have used - unsure why I thought it was.
  14. #379
    462 Post(s)
    So not happy with how the current Redarc water temp sensor was fitting by the mechanic years ago I have decided to change it. The way it was, the probe wasn’t even in the stat housing as the adapter was too long.
    Upon remove the stat housing cover and sticking my finger in there I couldn’t even feel the probe. At all. So I was wondering how accurate my water temps actually are. Whether the readings were more so residual temps from the block heating up rather than actual water.
    So I put the sensor in the lid where the low water sensor was and drilled and tapped a new spot next to it for the low water sensor. Now to find something to plug up the hole where the temp sensor was...
    It will be interesting to see if this makes any difference
  15. #380
    49 Post(s)
    It should make a difference. The probe will be swimming now..
  16. The Following User Says Thank You to jay see For This Useful Post:
    mudski (29th June 2020)
