6th October 2021, 09:50 PM
#671
Mudski GU Build Thread
I think I only changed this side maybe 18 months ago. But lack of use due to obvious reasons I think is a killer of seals.
6th October 2021 09:50 PM
6th October 2021, 10:45 PM
#672
Moderator
mudski
Time to change the axle seal, ugh! Not a hard job, just messy.
Ghee mate that looks pretty badly contaminated. Looks like you Ave had water in there too. Did you dump your diff oil Too? Or just jack up that side? Are you doing both sides?
Check out my Toy -->
Rogue Dung Beetle
6th October 2021, 10:46 PM
#673
Moderator
mudski
Also have the old GUrl a wash.
Attachment 82828
I spent 5 years building a GQ in a shed just like that one! Ah the Old Days! That was really living!
Rogue Dung Beetle
7th October 2021, 07:46 AM
#674
MudRunnerTD
Not a drop of water. It hasn't seen any. Lol. Diff oil is spotless too, wheel bearings are perfect and well greased still. I haven't changed the seal yet and I've just jacked up that side.
I have a genuine one but I am going to see if I can get a double lipped seal, if they are still made, and try this. When I was working for a truck spare parts place 15 years ago we used to get these double lipped seals and they worked really well.
7th October 2021, 07:51 AM
#675
MudRunnerTD
Haha you can say that now my friend since you have this nice and big shed with a hoist. I spend the better part of a solid day lying under the Patrol repairing a few things that I had neglected to do in the past and my back did not like it one bit.
MudRunnerTD (7th October 2021)
21st October 2021, 08:55 PM
#676
I knew I should have insisted on measurements. Needs to be across another 130mm. @ Winnie you said you wanted one. Will this suit yours?
24th November 2021, 08:17 AM
#677
Back in the garage it goes. I gotta figure out this electrical gremlin.
Keys out. If flick the switch for the rear lamp, the light goes on. I then select reverse and the intercooler fan comes on and also the relay for the check engine light starts to buzz.
Start the car and everything is fine.
Also. I turn the ignition on and the same relay will buzz, I start the car and it stops buzzing.
So I don’t even know where to start. Earth point is broken I’m thinking, but not sure where.
24th November 2021, 10:06 AM
#678
mudski
24th November 2021, 11:43 AM
#679
Check for rodent damage in the loom. Little bastards chew though the insulation and mash the wires together. Been gobsmacked at how quickly they cause damage.
24th November 2021, 12:30 PM
#680
jay see
Haha! Yeah I feel like doing that sometimes. The amount on time and money I've put into it I couldn't do it though.
mudnut
Bloody hope not!
