Page 52 of 91 FirstFirst ... 242505152535462 ... LastLast
Results 511 to 520 of 904
  1. #511
    175 Post(s)
    Hopefully the injectors reset will help out. I recall you talking to me about it agess ago.
    Also as for the thermostats... MB' thread here might give you some info.
    http://www.nissanpatrol.com.au/forum...er-Thermostats
    462 Post(s)
    Yeah Im looking at the total length of the stat more than the temp ratings. Trying to get the stat by pass to shut earlier to force coolant to flow through the radiator earlier and at a lower coolant temp. I have read some have even welded in spacer plates so the by pass on a OEM stat will shut earlier and had good success. I think using a different stat is easier.
    But we'll see what happens with the new squirters first....
  4. The Following 2 Users Say Thank You to mudski For This Useful Post:
    10G (7th October 2020), MB (7th October 2020)
  5. #513
    472 Post(s)
    K.I.S.S theory you are smashing tracks brother
    Definitely love your mythical busters approach of not doing two or three major changes at once for your own clarity squirters possiblity sharing
    mudski (7th October 2020)
  7. #514
    462 Post(s)
    So I’ve got the squirters in. 47nm torque really feels to light but...
    I’ve a got a longer stat to play with and I bought some water wetter. Hear d a lot of good words about this stuff.
    What do I have to lose? Really?
  9. #515
    472 Post(s)
    Nothing at Brother, Baseline The Pwick
    mudski (8th October 2020)
  11. #516
    462 Post(s)
    So I got the injectors in. Then stopped. There’s a lot a corrosion in the inside on two of the banjos only the spill tube.
    Kinda hard to see in the pic but these two are quite corroded, the rest were squeaky clean. I’m gonna ask the guy who did my injectors tomorrow for some input.
  12. The Following User Says Thank You to mudski For This Useful Post:
    mudnut (7th October 2020)
  13. #517
    462 Post(s)
    Mudski GU Build Thread
    Here’s the height difference between an OEM stat and the new one. I just need to pull back the lower by pass plate 3-4mm first.
  14. The Following 2 Users Say Thank You to mudski For This Useful Post:
    jay see (9th October 2020), mudnut (7th October 2020)
  15. #518
    May 2016
    8 Post(s)
    I am hopping this works ...
  16. The Following User Says Thank You to Tip12345 For This Useful Post:
  17. #519
    194 Post(s)
    @MB, I wonder if we could buy something like this for the Chev's? @mudski, could you supply the part number and the overall height dimension pls so I can check it? Thanks
  18. #520
    462 Post(s)
    DT79A Dayco.
    SPECS
    Flange diameter: 54mm
    Height: 62mm
    Flange to base: 40mm
    Vent valve: 29mm
    Celsius: 82°C
    Fahrenheit: 180°F
  19. The Following User Says Thank You to mudski For This Useful Post:
    PeeBee (8th October 2020)
