Page 72 of 91 FirstFirst ... 2262707172737482 ... LastLast
Results 711 to 720 of 904
  1. #711
    Jun 2018
    24 Post(s)
    Fark, that made no sense apologies....
    Quote of the year from @MB about @MB!
  2. The Following 6 Users Say Thank You to Cremulator For This Useful Post:
    BrazilianY60 (27th April 2023), growler2058 (31st March 2022), MB (1st April 2022), mudski (31st March 2022), Plasnart (31st March 2022), Rossco (31st March 2022)
    Feb 2011
    Shed
    45 Post(s)
    Fark, that made no sense apologies Mark Mate, please do put the hard yards in prepping your steel variants by way of taking them back to basics….coatings be gone for full carbon kinky bondages
    Kenoath! Glad I'm not the only one. I got vertigo trying to read that hahaha
  5. The Following 3 Users Say Thank You to growler2058 For This Useful Post:
  6. #713
    461 Post(s)
    Ah yeah I was warned about that. I'll be prepping the welded sections for sure.
    Just gotta fix my drill press before I continue.
    MB (1st April 2022)
  8. #714
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Mark, if you're going to put a 2nd piece of angle iron down inside that extension piece, it might be worth cutting a 5-6mm slot on other side so you can weld it to the hub as well.
    John
  9. The Following User Says Thank You to jff45 For This Useful Post:
  10. #715
    330 Post(s)
    Your front pulley looks like a taper with a left hand thread nut. Clean both tapers and give it a tap when it's back on and tighten the nut. Do you have the nut? If not it should be relatively easy to find one at a specialist bolt or tool store.
  11. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    Mickhead (2nd April 2022)
  12. #716
    Patrol Freak BillsGU's Avatar
    Jul 2010
    Thurgoona
    7 Post(s)
    The only thing I got out of all that is that MB has been sniffing something. ?????????????
  13. #717
    May 2016
    8 Post(s)
    just clean up the shaft and pulley 680 locktite I did this years ago still going think its a left hand thread so mine has no nut still goes
  14. #718
    461 Post(s)
    Yeah the first one is welded to the hub, then I found another piece of angle. I've only spot welded the RHS in, I'll either grind them out and weld the angle in properly or do it your way.
  15. #719
    461 Post(s)
    Yeah the nut is long gone, had the thing for maybe 15years and the pulley has never slipped too. I rang a few bolt and tool mobs locally and no one is willing to help. I'll just weld it on.
  16. #720
    330 Post(s)
    Just give both surfaces a clean and a rub with scotchbrite or something like an 800 grit. Then clean. Then place the pull on and give it a couple taps with a rubber mallet. If you have an oversize deep socket plate it over the shaft and hit the pulley on using the socket as a 360d press. I'd be very surprised 8f you couldn't get that left hand thread Nut from an All tools or Sydney tools to be honest mate. Maybe not a shelf item but they'd be able to get it in for you. Go in and flip the lid on one of the floor stock drill presses on display. Evolution has not really arrived yet mate. They will likely be the same.
