Page 83 of 91 FirstFirst ... 33738182838485 ... LastLast
Results 821 to 830 of 904
  1. #821
    461 Post(s)
    If you go down the remove and refit option and you want the screen done professionally yell out, my son does it for a living. I sure he'll look after ya..
    I may have to get his number mate. Ideally I want the screen removed, then left to me to fix it up, then get a guy back in to install a new windscreen.
    49 Post(s)
    Pm sent
  4. #823
    Legendary Alitis007's Avatar
    15 Post(s)
    Still got the buzzing relay mate but I have found many others with the same thing with no resolve. The buzzing stops as soon as the vehicle is running, so it’s on the back burner for now.
    Mine had been buzzing for over a year lol. Easy 5 minute job when you’re in the engine bay to buff the terminal and post, take off the body connection under the battery, buff brass tab and body with a sotchbright whizzer disc and do the same on the engine.
    Oh and if you’re pulling the screen get a genuine inner and outer window seal, the factory outer seal has a raised lip 3/4 of the way along to to deflect water up onto the roof and stops it flicking in through the door windows when it’s wet
  5. #824
    Hardcore jack's Avatar
    Ballarat Area
    25 Post(s)
    I had a similar buzzing issue years ago and Yendor pointed in in the right direction. Not sure if yours and &Mudski issue is the same as mine but have a look at what was causing mine. http://www.nissanpatrol.com.au/forum...ighlight=Relay
    Jack
  6. #825
    461 Post(s)
    The buzzing in mine is from under the bonnet. I'm not bothered by it to be honest. Its been doing it for years. I'll look at fixing it one day. Maybe.
  7. #826
    175 Post(s)
    Oh yeah I know how good that MX3 stuff is. I have it also.
    Got a tube of the good stuff for you next time I see you. Perfect for exposed winch connections.
    Been using it on my forever not a spec of rust or any corrosion! We use this on every connection on the lines.
    Sent from my Pixel 6 using Tapatalk
    mudski (6th March 2023)
  9. #827
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    So what’s the best thing to protect the cable lugs to the winch solenoid and winch motor from corrosion?
    I have a spray can that I have had for probably 25+ years. Works a treat. Just clean any corrosion (just boiling water) and give it a light squirt with this and it is done. Seems to last for ever. And I will never be able to use up the can.
  10. #828
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    On a similar topic, if you are just after a good penetrating liquid (rusty nuts etc) try a 50/50 mix of Auto transmission fluid and acetone. Best I have come across.
  11. The Following User Says Thank You to Brissieboy For This Useful Post:
    mudski (7th March 2023)
  12. #829
    15 Post(s)
    Mine was simple as dirty earths. I was chasing an other fault but cleaning them by chance sorted a couple of other random intermittent issues too which was a bonus
  13. #830
    461 Post(s)
    Mudski GU Build Thread
    Gave the old GUrl a bath today. Still scrubs up alright with original paint.
  14. The Following 3 Users Say Thank You to mudski For This Useful Post:
    jay see (11th March 2023), jff45 (12th March 2023), Plasnart (11th March 2023)
