Page 51 of 96 FirstFirst ... 4950515253 ... LastLast
Results 501 to 510 of 958
  1. #501
    Patrol Guru 0-TJ-0's Avatar
    Jan 2017
    South Australia
    11 Post(s)
    I’m going to remove the injectors this week and get them reset to factory as well.
    Interested to see if you notice a difference.
  2. #502
    476 Post(s)
    I bloody hope so. I am at my wits end with this. If this doesn't work my next move will be to disconnect the Redarc gauge.
  3. The Following 2 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (22nd September 2020), 10G (24th September 2020)
  4. #503
    May 2016
    8 Post(s)
    I look at the temperature with my non contact thermometer. down the hole next to the injector . That head mod is a walk n the park to do .
    I will wait and see how you get along with it . I am still working on my phantom over heat problem . Still looks like the dash fault . slowly working through the possibilities.....
  5. The Following User Says Thank You to Tip12345 For This Useful Post:
  6. #504
    476 Post(s)
    Squirters are out. I will send them off tomorrow to be reset to factory. God I hope this works...
  7. The Following 2 Users Say Thank You to mudski For This Useful Post:
    10G (24th September 2020), Rossco (23rd September 2020)
  8. #505
    so what are you taking outta your engine?
  9. #506
    476 Post(s)
    The injectors cob. Hopefully I get this dunga back on the road mate in time for our dictator premier to let us out so we can do another camping trip. Before we go back into lockdown again.
  10. The Following 2 Users Say Thank You to mudski For This Useful Post:
    10G (24th September 2020), Mickhead (24th September 2020)
  11. #507
    Oh when you said squirters I figured you had found some other thing to pass time in lockdown lol
  12. #508
    476 Post(s)
    You dirty bugger!
  13. #509
    476 Post(s)
    Gave the front pipe a birthday. Removed the exhaust lag and it was pretty rusted up. Rang Redback to see if I could get a replacement and they don’t make this type of pipe anymore. So I cleaned it up as good as possible, give maybe a gazzilion coats of Exhaust paint then some new lagging.
  14. The Following 5 Users Say Thank You to mudski For This Useful Post:
    10G (7th October 2020), Cremulator (26th September 2020), MB (24th September 2020), mudnut (27th September 2020), Rossco (25th September 2020)
  15. #510
    476 Post(s)
    Picked up my recoéd injectors afterwork today. The crack pressures were all over the shop, ranging from 105bar to 120bar. Now they are all 110bar. Factory spec is 100bar, plus or minus 10bar. So at worst, if it doesn't make a difference to the cooling, it will run better.
    Also been doing some research on the thermostat. It seems the factory Nissan stat's by pass valve is too short, needing about 20c above opening temp before the by pass valve will close the system so all water will flow through the radiator. Instead when the by pass is open, water mainly just flows through the motor, rather than going through the radiator, where it should.
    So what was done, from what I have read, is to use a longer stat. I have found a Dayco part number listed, so I will order one tomorrow.
    Also during my discussions with the chap who done the injectors, he's not confident what we have done will help, but he did also mention maybe fitting an external oil cooler. Which this has been on my mind to do for quite some time, but never really thought much about it.
    Keen to get it back together and see what happens.
  16. The Following User Says Thank You to mudski For This Useful Post:
