Page 26 of 91 FirstFirst ... 1624252627283676 ... LastLast
Results 251 to 260 of 904
  1. #251
    22 Post(s)
    Hi Mark. It actually has more to do with how the motors are wound. The Iskra is i believe a continuous wound units that is designed for a static machine operation and continuous load and when adapted onto a 12v winch it was found that they simply dont load up like a series wound motor. They take the load and keep going. Lets face it that is when things really get ugly. Loaded and lacking current and the Iskra will just keep pulling.
    There is a bit of confusion there. These are likely to be a series wound motor just like every other winch motor, as cranes, hoist, winches etc are the primary use of a series wound motor. The iskra is probably a continuous duty motor? Maybe more poles for more torque?
    There are basically 3 types of basic DC motor. Series wound, shunt wound and Compound wound (series and shunt)
    96 GQ coil/Cab
    08 G6eT
  2. The Following 2 Users Say Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (11th April 2020), mudski (23rd April 2020)
    Thanks Bene, good to see you about mate, hope your well. How is your TD looking mate? Have you got a plan bud?
  5. #253
    462 Post(s)
    So I really need to get my arse into gear and get this done and fitted. I went out yesterday to get a load of firewood and wanted to winch a great bit of timber up the hill a bit. Winch was dead as a door nail. Last use was winching the lumbered massive pine at my place with Rossco. It was playing up then but won’t work now.
  6. #254
    22 Post(s)
    I'm getting by. I have a plan of getting a GU and put my speed parts on it and have soley a touring type setup.
    I would like to do the snow trip if I find a decent rig in time. But there are so many over priced pieces of crap for sale
    96 GQ coil/Cab
    08 G6eT
  7. The Following User Says Thank You to Ben-e-boy For This Useful Post:
    MudRunnerTD (13th April 2020)
  8. #255
    462 Post(s)
    Righto. Oil time. Been reading over the webs and seeing different answers. 30w oil is recommended. Which I assume is engine oul. Can’t say I’ve seen a straight 30 gear oil. But I’ve read others just using your regular 80/90gear oil and similar types. 6 Fluid ounces is Warns recommendation. Stick with this?
  9. #256
    Lawnmower engine oil.
    mudski (13th April 2020)
  11. #257
    192 Post(s)
    Originally found some outboard gear oil close to what's recommended but since have just used normal gear oil which sure will be fine. Bout 180-200ml should do. .
  12. The Following User Says Thank You to Rossco For This Useful Post:
  13. #258
    462 Post(s)
    Righto. Which is the 30w engine oil I have. Cheers.
  14. #259
    462 Post(s)
    Mudski's High Warn High Mount Rebuild into an ARB GU Bar
    She’s nearly finished!
    I have the Iskra Mahle motor mounted on shortened Gigglepin motor mounting bolts.
    I then made up my own mounting bracket for the solenoid.
    My last issue. I seem to have misplaced the bolts for the freespool delete thingo...
    Other than that, and wiring the solenoid to the motor. It’s ready. Yeah baby!
  15. The Following 7 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (21st April 2020), Cuppa (21st April 2020), MB (20th April 2020), mudnut (20th April 2020), PeeBee (20th April 2020), Rossco (21st April 2020), Winnie (20th April 2020)
  16. #260
    192 Post(s)
    Holy moly Markie looks smick as too good to use lol . Sticker on top is upside down but. .
  17. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    MB (21st April 2020), mudski (21st April 2020)
