Page 35 of 91 FirstFirst ... 2533343536374585 ... LastLast
Results 341 to 350 of 904
  1. #341
    Advanced tryan277's Avatar
    May 2016
    Melbourne, Southern Burbs
    Once the tags are on, I'll be sending it off to be sandblasted then powdercoated. Any suggestions before I take it away?
    How are the moccy's holding up??? Need a new pair yet or getting them sandblasted as well!!!
    Have you done a test fit to the vehicle? How much plastic grill do you have to remove?
    Trevor
    462 Post(s)
    Quote Originally Posted by tryan277 View Post
    Trevor
    Mate the moccos are holding up really well. I will require a new pair though, which I'll get as soon as the Vic markets re open. Lol. Not sure on how much grille I'll have to remove, I'll get to that when it comes to fitting it up.
  4. #343
    462 Post(s)
    Mudski's High Warn High Mount Rebuild into an ARB GU Bar
    So now I have to wait until ARB get my bits in. I hate waiting....
    So I’ve pulled the dash apart and will start on the in cab wiring of the isolator and winch in/out switch.
    Looking at the back on the in/out switch there’s too many pins, 7 of them. Lol. Anyone have a wiring diagram for this part?
  5. #344
    462 Post(s)
    I’m going to move my light bar and spotties switch to down on the gear shift console too so the winch switches will be in the best spot.
    Rossco (26th May 2020)
  7. #345
    192 Post(s)
    Hopefully this helps. .
  8. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    mudski (26th May 2020), PeeBee (26th May 2020)
  9. #346
    49 Post(s)
    I can't remember for the life of me mate. Might have something on my build thread if not there's always your two other friends Google and YouTube..
  10. The Following 2 Users Say Thank You to jay see For This Useful Post:
    mudski (26th May 2020), Rossco (27th May 2020)
  11. #347
    49 Post(s)
    https://www.facebook.com/groups/1444...8026831490128/
  12. The Following User Says Thank You to jay see For This Useful Post:
  13. #348
    462 Post(s)
    Thanks.
    Just gotta work out the schematics of it all. Do I need to use any relays? Also I'm thinking of getting some small 2mm, or similar, 7 core trailer wire and use this as a loom to out of the cab. I should need anything heavier you think?
  14. #349
    192 Post(s)
    Yeah think I just sketched it all before I did it to get my head around it all. Trailer wire should be fine, don't need any relays big solenoid does everything. Worth thinking about when you do it is putting buttons up front on the bar very very handy and also some strip lighting above the winch which picks up power fron the isolator, very handy in the dark obviusly. . .
  15. The Following 2 Users Say Thank You to Rossco For This Useful Post:
    mudski (27th May 2020), Winnie (27th May 2020)
  16. #350
    Yep buttons on the bar are a must! I left them out and really regret it, running out the winch rope solo is a mission now. Need to find some motivation to add them in.
    A light above the winch that illuminates when you activate the in cab isolation switch is also a bloody good idea too, I didn't do that either damn it.
  17. The Following User Says Thank You to Winnie For This Useful Post:
