Page 80 of 91 FirstFirst ... 3070787980818290 ... LastLast
Results 791 to 800 of 904
  1. #791
    I did not know the 4.8came out with manual. The oil smells really burnt. This is where my burning smell was coming from on the last hour of the trip to Cape Jaffa. It was hot as hell outside, I was towing and really pushing the GU. Every time we slowed or stopped at an intersection the cabin would fill with this awful smell.
    I’ve put new oil in, I’ll run it for an hour or so and then drain and put fresh oil in again. Transfer oil looked fine but I’m changing that, the diff oils look d perfect still.
    New battery in. Not an Optima but I can’t justify spending a lot so this one will do.
    Also fitted these terminal blocks. A bit neater.
  4. The Following 8 Users Say Thank You to mudski For This Useful Post:
    BigRAWesty (15th January 2023), Cremulator (14th January 2023), Hodge (14th January 2023), jay see (14th January 2023), jff45 (15th January 2023), pearcey (14th January 2023), PeeBee (14th January 2023), Stropp (14th January 2023)
  5. #793
    Patrol Guru Sprock's Avatar
    Jun 2015
    Heyfield Vic
    35 Post(s)
    Yeah that gearbox oil doesn’t look good, how many Ks has that oil done? Those terminal blocks look shitot- I’ve never seen them before.
  6. #794
    Gear box oils probably done 20-30thou.
    But I know I cooked it on our last trip. Towing, it was hot and using 5th. Happened once before when I first got the TD transplant done. There is a shit load of torque going through the driveline when towing, and in 5th gear, the workshop warned me.
    Changed the oil out and it all good now.
  7. #795
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    Where did you get those terminal blocks? Best looking solid meaty units that I have seen, and with plenty of connection points.
  8. #796
    194 Post(s)
    Quote Originally Posted by Brissieboy View Post
    I thought the same and found these on ebay yesterday, now ordered!
    https://www.ebay.com.au/itm/17392469...4f7d%7Ciid%3A1
  9. The Following User Says Thank You to PeeBee For This Useful Post:
    Brissieboy (16th January 2023)
  10. #797
    Jun 2015
    Heyfield Vic
    35 Post(s)
    I was told yrs ago not to labour tow In 5th- ie: don’t pull in 5th- fine to coast down hill & cruising along the flats but never pull in 5th because 5th gear is tiny in most 4wd gearboxes- about the size of a 50c piece ( that’s what I was told) anyway it gets hot & cooks the oil then it destroys everything. That was in Ranger/ BT50 gearboxes & im lead to believe most others aswell so I’ve just stuck with that. Happy to be told otherwise.
  11. #798
    Apr 2021
    Brazil
    I'm with everyone else regarding the batery blocks, nice stuff! On a second look, what have you done for the fusible link? I believe it is incorporated into the positive block, isn't it?
  12. #799
    Patrol Freak jff45's Avatar
    Morayfield, QLD
    13 Post(s)
    Mark, to insulate the positive side I made a red acrylic cover with a heat gun. They just looked too easy to short circuit..
    John
  13. The Following 5 Users Say Thank You to jff45 For This Useful Post:
    BrazilianY60 (15th January 2023), jack (15th January 2023), mudski (16th January 2023), PeeBee (15th January 2023), Plasnart (15th January 2023)
  14. #800
    175 Post(s)
    Yep. See ya later oil dip stick.
    Sent from my Pixel 6 using Tapatalk
  15. The Following 2 Users Say Thank You to Hodge For This Useful Post:
    BrazilianY60 (15th January 2023), jff45 (15th January 2023)
