Page 86 of 91 FirstFirst ... 36768485868788 ... LastLast
Results 851 to 860 of 904
  1. #851
    Do not run the engine with the alternator disconnected. I destroyed one once, doing just that. With the multimeter connected in series with the negative to earth (do it on the 10 amp setting), there should be a quick spike in parasitic draw, for the clock and sound system, etc, then should drop to bugger all. If it is above the small milliamp range, then try pulling fuses and relays, before disconnecting the alternator.
  2. The Following User Says Thank You to mudnut For This Useful Post:
    mudski (14th August 2023)
    465 Post(s)
    Hmm, that just went over my head like a low flying duck. I'll YouTube it!
  5. #853
    193 Post(s)
    Yeah I had a bad alternator that had parasitic draw was a PITA. . . When you say don't run motor with alternator discontented Muddy do you mean unplugged but still with belts attached or other way round, and why does this bugger them?? . . .
  6. #854
    Unplugged but belt on. A very long time ago (decades) I think had the main output disconnected and started the engine. It blew the regulator by the time I got out of the cab and realised my mistake (maybe 30 seconds).
  7. The Following User Says Thank You to mudnut For This Useful Post:
    Rossco (14th August 2023)
  8. #855
    465 Post(s)
    Mudski GU Build Thread
    @mudnut ;
    I think I’ve got it set up right.
    And after a few minutes it dropped
    I noticed even opening the door on the car, even without the interior light on the reading goes up from .08 to .10
    From what I’ve read that is normal.
    Bidja (14th August 2023)
  10. #856
    465 Post(s)
    Removed every fuse. The only fuse that mad the dmm move was the air bag fuse. From .10 to .09.
    Opening the door read more.
  11. #857
    Patrol Freak Bidja's Avatar
    Jul 2017
    Southern Table Lands, NSW
    37 Post(s)
    Not a collapsed cell in battery?
    Maybe put it on chg over night and then have battery joint do a load test.
  12. The Following 2 Users Say Thank You to Bidja For This Useful Post:
    mudnut (14th August 2023), mudski (15th August 2023)
  13. #858
    @mudnut ;
    The reading is a little on the high side, but a fully charged battery should handle it overnight.
  14. #859
    194 Post(s)
    I would expect a collapsed cell would be in the order of 2.2V drop not 11V.
  15. The Following User Says Thank You to PeeBee For This Useful Post:
    Bidja (15th August 2023)
  16. #860
    465 Post(s)
    So I have found the culprit, but not sure how to fix it.
    This first pic looks of the dmm you can see the circuit breaker is off.
    This breaker is fed from the main battery and goes to a fuse block, this fuse block feeds power to each relay, Oem and aftermarket in the original relay housing.
    Probably 10 years ago I modified the relay box to house all the added relays that were strewn all through the engine bay. It has worked really well.
    This is what happens when i activate the breaker.
    I tracked it down to fuse number 4, which feeds the relay for the spot lights.
    I remove the fuse, the reading drops. I put the fuse back in and remove the relay. Nothing. It stays the same!
    Why?
    This is about as far as my lecky knowledge goes with fault finding.
    Any ideas for what to do next?
    I removed every relay also with no change.
