Page 82 of 91 FirstFirst ... 32728081828384 ... LastLast
Results 811 to 820 of 904
  1. #811
    Sep 2011
    adelaide
    18 Post(s)
    Quote Originally Posted by Brissieboy View Post
    And this one slipped out of my hand onto the second battery between positive and the retaining bracket.Attachment 86493
    No wonder it slipped outta your hand it`s only SIX inches long ,LMAO.
  2. The Following 5 Users Say Thank You to pearcey For This Useful Post:
    Brissieboy (18th January 2023), Cremulator (18th January 2023), Hodge (17th January 2023), mudski (17th January 2023), Plasnart (17th January 2023)
    Better than a hole in the AC line on your Mrs brand new car the day before you are towing a caravan for 8 hours on a 40 degree day.
    Ask me how I know.
    hahahaha. I was gunna Tag you! LOL
  6. #813
    465 Post(s)
    Mudski GU Build Thread
    So what’s the best thing to protect the cable lugs to the winch solenoid and winch motor from corrosion? Both end on my hi mount were pretty bad. All cleaned up now though.
    I was thinking to use dielectric grease. Went to Jaycar yesterday and they didn’t know what it was. Lol.
    I use to use this stuff all the time in my nerdy sub zero Vapo chilling computer days to stop condensation killing the computer.
  7. #814
    175 Post(s)
    I use a combo of the following Mark.
    Lanotec and Inox MX3. Swear by it.
    Not just elecy stuff that's weather prone , but everything in general. I've thrown CRC and wd40 in the bin years ago when I discovered this.
    Sent from my Pixel 6 using Tapatalk
    mudski (5th March 2023)
  9. #815
    465 Post(s)
    Then there’s the windscreen leak issue. Do it just silicone up the outer rubber and ignore that there is probably a rust issue? Or. Remove the windscreen and take the time to properly repair it? Which will take much longer to do.
  10. #816
    465 Post(s)
    Oh yeah I know how good that MX3 stuff is. I have it also.
    Hodge (5th March 2023)
  12. #817
    Legendary Alitis007's Avatar
    15 Post(s)
    Hey Mark had a read through your journey the trol has taken, well done mate! Did you sort the buzzing relay out? I had one do the same recently and it was as simple as cleaning the neg terminal earths to the body and engine. Your winch wires can be sealed after cleaning and re connecting wire liquid electrical tape like they do with marine wiring. There’s probably other products on the market but boat electronics in salt water corrodes fast so look at what they use to help with that situation.
  13. The Following User Says Thank You to Alitis007 For This Useful Post:
  14. #818
    175 Post(s)
    I forgot !!!
    Next time I see you I'll give you a tube of electrical corrosion inhibitior we use on tower lines... Ugly smelly heavy duty shit..We literally call it dog shit. Smeared some on my winch connections for years. No issues !
  15. The Following User Says Thank You to Hodge For This Useful Post:
  16. #819
    49 Post(s)
    If you go down the remove and refit option and you want the screen done professionally yell out, my son does it for a living. I sure he'll look after ya..
  17. The Following User Says Thank You to jay see For This Useful Post:
  18. #820
    465 Post(s)
    Still got the buzzing relay mate but I have found many others with the same thing with no resolve. The buzzing stops as soon as the vehicle is running, so it’s on the back burner for now.
