Page 89 of 91 FirstFirst ... 39798788899091 LastLast
Results 881 to 890 of 904
  1. #881
    462 Post(s)
    I did think it’s time to upgrade to a lithium battery, but then realising I also need to upgrade my Ctek 250 dc-dc charger as well quickly put a stop to that thought.
    49 Post(s)
    I thought the same and also came up with the same result..
  4. #883
    462 Post(s)
    Gave the old GUrl a quick scrub before getting her dirty over a 4 day Fecking weekend starting this Friday at Enoch’s point on the Big River. Cannot fecking wait!
  5. The Following 5 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (18th October 2023), jay see (17th October 2023), mudnut (18th October 2023), Touses (18th October 2023), Trolatron (7th December 2023)
  6. #884
    Apr 2021
    Brazil
    Looking mint!
  7. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    mudski (18th October 2023)
  8. #885
    462 Post(s)
    Looking mint!
    Thanks. Still not a bad duco after 22 years. I have found a little spot of rust, quite bad but small, hiding behind the snorkel, which would be snorkel and windscreen out job. Not really wanting to do that though.
  9. #886
    462 Post(s)
    Mudski GU Build Thread
    So after piss farting around using and putting up with the shitty rose joints on the extended sway bar links, that wear out almost instantly and require to be greased every time you hit the dirt, plus the grey area over their legality, I am making my own. Lol
    Got some heavy steel tubing, cut to the length I need, drilled and tapped one end to M10x1.25 to hold onto a mini tie rod.
    I just need to figure out whether to use 8.8 grade threaded rod for the top end or go the next tensile strength up. 10.2 I think it is.
    10.2 is obviously stronger but has less give than 8.8, so it could potentially snap if flexed too much, but that’s what the mounting rubbers are for, to allow the rod to pivot in the mounting hole.
    I’ll do a test run on the fronts. Then do the rears next if these work out.
  10. The Following 5 Users Say Thank You to mudski For This Useful Post:
    AB (27th November 2023), BrazilianY60 (21st December 2023), Cremulator (27th November 2023), jay see (28th November 2023), Touses (27th November 2023)
  11. #887
    462 Post(s)
    Finally got around to finishing one link. I used 10.9 m10x1.5 all thread in the top.
  12. The Following 4 Users Say Thank You to mudski For This Useful Post:
    BrazilianY60 (21st December 2023), Cremulator (20th December 2023), jay see (21st December 2023), Touses (21st December 2023)
  13. #888
    462 Post(s)
    So I have a weeks grace from hell, AKA work, I’m not going anywhere so I thought I’d pull the Patrol in the garage and do some maintenance and some preventative maintenance. A can of worms I have opened….
    There more on this list also.
    I removed the rear tail shaft as the yoke on the gearbox is worn out.
    The cup on the uni can be inserted by hand, no force needed at all. Not good.
    Problem here. Nissan don’t sell this part, nor does Hardy Spicer and Drivetech, and I’m not keen on forking out a small fortune for a complete second half tail shaft.
    So not sure what to do here. I’ll wait until I’m back at work and send the old one off to Hardy Spicer to see if they can match it up.
  14. The Following User Says Thank You to mudski For This Useful Post:
    AB (29th December 2023)
  15. #889
    462 Post(s)
    Tie rod and drag link end boots need to be replaced.
  16. The Following User Says Thank You to mudski For This Useful Post:
  17. #890
    462 Post(s)
    And I’ve had a small issue for a while where I couldn’t pump up the tyres. For some reason any air chuck I used would not pump air into them.
    Long story short Darren last year suggested maybe wind out the valves a little. This worked. So every time I had to put air in the tyres I had to loosen the inserts a little.
    So I was guessing the seal on the valve insert was worn out from using a tyre deflator many times over.
    So I finally changed them out. One insert was actually broken.
    So we’ll see if new inserts help.
  18. The Following User Says Thank You to mudski For This Useful Post:
    Cremulator (29th December 2023)
