Page 43 of 91 FirstFirst ... 33414243444553 ... LastLast
Results 421 to 430 of 904
  1. #421
    49 Post(s)
    Hey Mark, did you get around to installing the winch switches on the bar. You can save me some googling time.
    461 Post(s)
    Haven't even got the bar on the Patrol yet mate. The winch in mounted in the bar and the bar is sitting on the ground. I'm going fab up a pulley system from my balcony to winch it up, hopefully the balcony holds it, then do a test fit. As I think the power steering cooler will be in the way still.
    Once its all mounted in then I'll worry about wiring.
  4. The Following 3 Users Say Thank You to mudski For This Useful Post:
    jay see (31st July 2020), MB (31st July 2020), Rossco (31st July 2020)
  5. #423
    472 Post(s)
    G’day Mr Mark,
    Hope you and the family are well mates!
    This may possibly assist as to what I conjured up for my ute setup.
    https://daviescraig.com.au/product/t...late-hydra-677
    The old unfortunately discontinued Millweld bar (-80mm mount) I found zero chance of allowing the OEM power steering split coolers and lines to stay in place without severely rubbing through one day.
    I was having issues also with our 12.5” wide tyres overheating the fluid under demanding twists etc..
    Thankfully didn’t have to fabricate a single bracket either, simply utilised the OEM cooler brackets in different positions and a bit of bending/tweaking to finally mount the aftermarket cooler behind the High Mount gearbox to the drivers side of radiator.
    Your flash newly painted ARB bar may not require this mate but my PS fluid appeared to appreciate the modification anyhows
  6. The Following 2 Users Say Thank You to MB For This Useful Post:
    mudski (1st August 2020), PeeBee (31st July 2020)
  7. #424
    461 Post(s)
    Thanks Mark. I'm also running two thermo's, the second is right where you have your cooler. I think I might have to get inventive soon. Just gotta get the bar on temporarily first to see where I'm at.
    MB (2nd August 2020)
  9. #425
    461 Post(s)
    Mudski GU Build Thread
    Managed to get the bar on. I have about 5mm before the winch motor hits the cooler. But it’s on.
  10. The Following 6 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (2nd August 2020), jay see (2nd August 2020), MB (2nd August 2020), mudnut (2nd August 2020), MudRunnerTD (11th August 2020), PeeBee (2nd August 2020)
  11. #426
    461 Post(s)
    Gave the beast a wash too. Something I forgot to do when I first parked it up in the garage. No more dirt falling on me when I’m under it.
  12. The Following 2 Users Say Thank You to mudski For This Useful Post:
    MB (2nd August 2020), PeeBee (2nd August 2020)
  13. #427
    194 Post(s)
    Looks good Mark, well done, top effort.
  14. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    MB (2nd August 2020), mudski (2nd August 2020)
  15. #428
    461 Post(s)
    So all is left is...
    • mount the solenoid, somewhere
    • wire in the solenoid to the winch motor
    • cut and mount the grille
    • Move the ARB twin compressor wiring to the main battery so the compressor gets priority voltage when running.
    Then remove the ARB deluxe side steps, weld on some extra bits to make them into rock sliders.
    • fix and re attach the rear 1/4 guard flare which was ripped off
    • Get a new double din head unit.
  16. The Following 3 Users Say Thank You to mudski For This Useful Post:
    jay see (2nd August 2020), MB (2nd August 2020), PeeBee (2nd August 2020)
  17. #429
    472 Post(s)
    Perfecto Mr Mark, looks truly awesome Mate!
    Super intrigued about these essential double din head units though, where do we find them bloke, Thailand or Tasmania :-)
  18. The Following User Says Thank You to MB For This Useful Post:
  19. #430
    461 Post(s)
    Made up an ally mounting plate for the circuit breaker this arvo. Rather than have it floating around and occasionally arcing out. Then ran a cable from this over to the lhs of the engine bay for the ARB twin compressor to run off.
  20. The Following 2 Users Say Thank You to mudski For This Useful Post:
    0-TJ-0 (9th August 2020), jay see (9th August 2020)
