Page 8 of 8 FirstFirst ... 678
Results 71 to 77 of 77
Thread: The safest cleaning solvent for alternator interior?
  1. #71
    Patrol Freak gaddy's Avatar
    redlands
    12v only , led lights only turned on when needed, cooking etc , i just like to keep it simple , bit like me !
    Legendary dom14's Avatar
    Somewhere inside Victoria, Australia :)
    38 Post(s)
    Quote Originally Posted by gaddy View Post
    That's the reason for the longevity of the aux batteries. LEDs don't consume lot of power. If you try to run the fridge for four days without charging the batteries they won't last anywhere near four days, hence the reason for the preference of solar as a backup.
    RB30, some 2-3 inch lift auxiliary LPG tanks
    Few more mods on the way
    http://www.worldwildlife.org/species/tiger
    https://www.panthera.org/
    Cheetah Outreach
  4. #73
    redlands
    Fridge only runs off the car , half hour - hour drive each day , got told years ago by fridgies i worked with years ago remove the travel bag from the fridge , ( would you wear a jumper when its hot )1 cold beer out 1 hot beer in , sweet as
  5. The Following User Says Thank You to gaddy For This Useful Post:
    dom14 (1st December 2015)
  6. #74
    38 Post(s)
    I must do something wrong ! I run a fridge (old engel ) charge phones , dvd players for the kids , charge the van battery , run lights and shower pump , 1oo amp alt cheap projector vsr , 90 amp deep cycle as a second battery and same in the van hooked up via anderson plug when towing , and can sit for to 4 days with out even getting close to killing batteries , and get around 5- 7 years battery life , i do plug into a cetec charger at home to keep them conditioned , no solar ,
    Should add usually go for a drive most days for maybe 1hr all up ,
    Sorry to break the news to you, but you're doing everything right.
    Cheetah Outreach
  7. The Following User Says Thank You to dom14 For This Useful Post:
    gaddy (1st December 2015)
  8. #75
    redlands
    For what it's worth spent 3 and a half days at birdsville in September, only time the car moved was to spend a sun set on big red maybe 1.5 hrs drive time , no dramas at all , put a hot ctn of beer and a slab of bundy cans through the fridge as well
  9. #76
    38 Post(s)
    What was the midday temperature in Birdsville when you were there in September? Mild or hot?
    Cheetah Outreach
  10. #77
    redlands
    Low 30s
  11. The Following User Says Thank You to gaddy For This Useful Post:
